95 eprom ecu on 98 dsm
greenwitenvy98
151
Jun 6, 2010
miami, Florida
i need some help i have a 98 tsi but to ecmlink it i bought a 95 eprom i know yu could of converted the 98 ecu but to make my life easyer i got a 95 eprom now my question is do i have to invert any wires on the ecu itself or not
just swap out the plug wires strait from the coil pack and you will be good to go. nothing else is needed.
If you do not have a 95 CAS then you also need to go to the "MISC" tab and click the box that says "Use non-95/96 style cam angle sensor". If you don't click on it then it will be a harsh ride if it starts due to the CAS signals being inverses. This will cause the fuel injectors to fire at the wrong time unless the box is checked.
