2G 95 EPROM ECU in 98 GSX
if your gonna be using an eprom chip then they can set it for that year and model with the other modifications of the burn itself
Just switch the spark plug wires at the coil pack. Stand in front of your coil pack, take the first 2 wires and put them where the other 2 are and vice versa. Done :)
Standing in front of the car from the driver's side to the passenger's side, number the cylinders and coil packs from 1-4 in your head.
Plug 4 to Coil 1
Plug 3 to Coil 4
Plug 2 to Coil 3
Plug 1 to Coil 2
I can take a picture if you need one, but you're basically swapping the two outside and two inside wires on the coil pack. Also, the chip will need CAS inversion built in to function correctly. The injectors and all other wiring can stay the same.
Just for reference, here's what it looked like on my old 2.0
Hope that helps,
Andy
i think i'll be fine but i plan on getting DSMLink and I was hoping if my 95 ECU is indeed EPROM that I can just run a non-EPROM ECU in the meantime while mine is being socketed. possible or no?
