- Year
- 1995
- Model/Trim
- Eagle Talon TSi
- Transmission Type
- Manual
- Mods-Bolt-on
- TD05H-14B Turbo | 3" Custom Catback w/ Magnaflow Muffler | 3" ExtremePSI Downpipe | SBR/DPH Full IC/Intake Piping | K+N FIPK | Aluminum Radiator | Joe P MBC @ 14psi | Rebuilt 1G TB w/ FIAV Bypass | Crushed 1G BOV | 2G Non-Cruise Throttle Cable | 180 Thermostat | Walbro 190lph Fuel Pump | NGK Wires | NGK BPR6ES
- Mods-Engine
- Rebuilt/Swapped 6-Bolt | Clearwater Stage I 6-Bolt Head | ARP Headstuds | Mitsubishi Metal HG | Balance Shaft Eliminated | Mighty Max OFH | ITM Revised Lifters
- Mods-EMS & Logging
- Greddy Turbo Timer | Autometer Ultra-Lite Boost Gauge | ELM327 Bluetooth OBDII w/ Torque App
- Mods-Drivetrain
- Stage II TRE Transmission | ACT 2100 w/ Street Disc | XACT Streetlite Flywheel | Symborski Shifter Bushings | Under-Hood Shifter Cable Bushings | B+M "Clone" Short Shifter | SBR SS Clutch Line
- Mods-Handling
- Tokico Springs | Tokico Illuminas | Prothane Motor Mounts | RRE Front Camber Kit | RRE Rear Camber Kit | 97-99 GS/T Bronze Wheels | Kumho Ecsta SPT 225/50/16 | Brembo Cross Dimpled + Slotted Rotors | F - Hawk HPS Pads / B - PBR Metal Master Pads | Techna-Fit SS Brake Lines
- Parts Wishlist
- DSMLink, Rota D2 16x8 +40, Meagan or D2 Coilovers, Custom FMIC, F+R Swaybars, F+R Strutbars, Lower Tie Arm, and fixed oil leaks!
- 1/4 Mile E/T
- 12.064
- 1/4 Mile MPH
- 114.530
- 1/8 Mile E/T
- 7.734
- 1/8 Mile MPH
- 91.760
- 60' Time
- 1.678
- Timeslip Details
- Tires : Street Radials
- Dyno TQ
- 346.9 lb/ft
