2G 7 bolt head removal process
Harley_2g_gsx
Dec 18, 2017
Spokane Valley, Washington
My 99 gsx recently spun a rod bearing and i need to pull the head off to make sure its not damaged. What is the full process for removing the head?? I know there is a special order that you have to remove the head bolts in, but what about the timing components and water pump and all the pulley and belts??
Is the engine already removed from the car?
No, the engine is still in the car. Im not gonna be the one swapping out the engines. Im checking the head before it goes to the shop so i know before hand if need to find a head or if that one needs rebuilt or if its fine to swap on to the new block.
Good tip on the tensioner.
Edit: a good tool for that is a small hex key if you don't have spare grenade pins.
