7 bolt ARP head bolts
caged
104
Jan 2, 2009
Brisbane, Australia
Hey iv some how been given Arp head bolts instead of studs. Iam uming and arring about just using them. Its a 7 bolt evo 3 engine going for 550whp with an HX40 pro. would you use them or buy new studs? They look the same as the studs but are just bolts. Does anyone know what to torque these up to? Arp doesnt have them on there site and it didnt come with instructions. Cheers Josh
ARP Head studs only come in studs, the stock 7 bolt head bolts are bolts. And yes, if they don't say ARP on them, then they are not ARP. Also, there is a handful of people who pushed stock blocks past the hp you wish to reach. How reliable is it, no one knows. Every motor is different.
They are definitely 12 point Arp head bolts. They are stamped arp and came in an arp box that had arp head bolts printed on it. When I'm back form work in 1.5weeks ill get the pics and part number.
12 point head not 12mm thread. They are 11mm.
That would be them I think. Thanks for that. I would call up arp but being in a different country and time zones makes it hard, I think ill try email them. Next question is would you use them? They appear to be made from the same material as the studs so I'm just assuming they are just not as accurate to torque as the studs, would that be the only negitive?
Just found out that the ARP site has become usefull since I used it last. torque spec is 80ftb. Cheers
