7-bolt 4G63 Crank Removal
96GST96
49
Jun 15, 2011
Gainesville, Florida
I've done an extensive amount of research on how to actually take the crank out, not just remove the pulley. I'm a visual learner rather than a literary learner. So far I've got all the pulleys off, and the oil pan (short block out of car) I've got it turned upside down, and all bolts are removed. I just took the crank sensor off and now I'm kinda stuck LOL. Doing this solo isn't going as well and easy as I had hoped. I've looked up Jafrob and others, but cannot find a 4G63 7-Bolt Crank removal video online either. Can anyone assist me in exactly what I need to do? I'm taking it out so I can swap it into my 4G64 block, as I'm putting together a 'destroked' 2.2L machine.
Thanks guys and gals! :rocks:
You need to take out the rear main seal carrier as well. You also need to take the main girdle out by unbolting everything. You also need to unbolt the rod bearing caps. After that you should be able to pull the crankshaft out. You need to remove the front case (oil pump) by taking all of the bolts off the front.
Yah the main girdle is in there pretty good. After your bolts are out you need to use some muscle and pull it on out.
Post up some pictures if you're still stuck
  • For sale 2g 2G 7 Bolt Lower Timing Cover
    2G 7 Bolt Lower Timing Cover $80 + shipping & paypal fees* there are a few flaws ( pictured )...
  • For sale 2g 2G Manual Shifter Cables ( including NEW bronze bushings )
    2G Manual Shifter Cables $90 + shipping & paypal fees* I will be including NEW bronze bushings...
  • For sale 4G63 Race parts.
    It is the time to make room to improve the DSM, getting rid of some extra parts I no longer...
    • GST2012GSX
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
