420A 420a easy power?
Aside from nitrous use, I wouldn't use "easy" and "power" in the same sentence about a 420A. The easy spectrum would include typical bolt ons such as:
- Cookie cutter exhaust headers
- "cold" air intakes
- Ignition coils/cables
- and crankshaft pulleys.
None of which make a huge difference alone, and even the conjoinment of them wouldn't add much power. Aside from the cylinder head being a restrictive factor, the stock ecu is unable to advance ignition timing above a certain value- which happens to be quite low at only 6 degrees of timing. It is also unable to recognize increased airflow at the MAF to add fuel accordingly. If I were to build another 420A, MegaSquirt would be my very first upgrade (aside from any overdue maintenance). Though this isn't necessarily easy or cheap, it will be the single best upgrade on your journey. And a great opportunity to learn a new skill.
MegaSquirt aside, here's my recommendations. Don't waste your money or time on cookie cutter bolt ons, not yet. Start with getting a 60mm throttle body. I actually have an extra that needs to be modified. Message me if interested in that, but you'll also need to bore the plenum opening to approximately 58-59mm. Doing this will remove some of the 420A's airflow restriction. I still had the stock computer installed when I performed this modification for the first time. This will greatly increase throttle response. I'm sure no one has researched this modification on a dyno or a flow bench, but the result speaks for itself. This isn't hard to do, but will take time and patience. A proper plenum porting could take a few hours.
The next most effective modification I found was raising compression ratio. But we're talking about a full engine rebuild here. Either with forged pistons, shaved cylinder head, semiflat valves or all of the above. This improves horsepower at every rpm. I would only consider this "easy" if you're experienced with building engines, though the 420A is not very complicated.
This is not to say that the basic bolt ons are useless or unnecessary. Each one shines in a specific scenario. For example: the exhaust header. Bolted up to a stock engine, it won't do much in terms of power gains. It is shiny though. Now: bolted up to an engine with oversized valves, high lift camshafts, and efficient intake: it's the very modification you need to ensure that the exhaust is not a restriction! Remember, the engine basically  is an airpump. The ability to evacuate more air is helpful if the intake has also been increased. Otherwise you risk slowing air velocity, which is counteracting.
I'll never be the person to advise selling it and getting a turbo model. But I will say that an equal investment in a 4g63T engine build will indefinitely produce better results. In fact I greatly enjoying tinkering with 420A's, and researching ways to improve their performance. But we're yet to see a 420A equipped Red Demon
after all :beatentodeath:
Well porting definitely isn't out of the question, I've got plenty of experience rebuilding it wouldn't be hard just time time consuming. And easy is a general term just modifications with proven results.
I've considered just buying a tsi or gst/x but everything is clapped out and expensive so not even worth it
What throttle body are you using? 60mm off of what?
All I have now is this comparison image. I can take installed pictures tomorrow.
sadly the 420a does well in its stock form and bolt on stuff doesn't yield a noticeable result but it would really only take a day to slap on a chinese turbo kit. a set of cams and springs would also see some decent gains
I know there used to be short tube headers and a downpipe on eBay for like 80 bucks I don’t know if they’re still being sold but headers and a cat delete will do wonders for the car
  • Wanted 2ga side markers
    Looking for 2ga side markers
    • Rohitter7878
  • For sale 2g 2G Fwd Thermal Research exhaust
    2g Fwd Thermal Research cat back exhaust
    • ari2gdsm
  • For sale Used Tial 44mm wastegate
    Looking to sell my used Tial 44mm wastegate. Legit Tial gate, verified by Tial. Can send...
    • Anfurnyy
  • For sale 1g 1g stock mass air. 4G63T.
    Stock 1g mass for turbo. Car ran was all stock. Hit in the rear quarter hard. 92 Tsi. Pulled...
  • For sale 1g 1G AWD Engine Side Splash Shield
    1G AWD Engine Side Splash Shields $55 a piece + shipping & paypal fees* I don’t have any...
