2G GSX Crossmember issues
Phardo
63
10
Jan 8, 2016
compton, California
Hi Dsm world,
I'm in the process of installing a top mount T3 manifold on my Gsx, but I ran into a little problem. The lower part of the manifold is hitting the top side motor mount located on the crossmember.
Has anyone come across this issue, and if so what did you guys do. I found a custom made bulfab crossmember, but I do not like the front tow hitch it comes with.
Any info will help.
Thank you
I wonder if bullfab would make that cross member without the tow hook? I've always thought a lift point would be more beneficial than that tow hook. Seems like you just need the mount to be smaller which the bullfab one would be.
