Resolved 2G Coolant hose near alternator
Vector
4
Jun 6, 2019
St.paul, Minnesota
Does anyone know what coolant hose this is and where I I could buy it? Mine is super soft and started leaking pretty heavily. I haven't been able to find it while searching online but I could just be searching the wrong things.
It is for the oil cooler. Goes from the bottom of the water pipe to one of two oil cooler nipples where the oil filter is. And for what it’s worth out of the probably 6 that I have of them; 6 of them are pretty soft. Idk why they are like that but I haven’t found one that’s not. Also probably wanna try to put a bag over your alternator before removal. Working on power steering and the water pipe recklessly usually earns you a new alternator if it’s old.
-Daniel
You can get an oem one i believe if not look on ebay as they make a silicone kit for the cars and all these little hoses are included as part of the kit
Mitsubishi part number MD309661, if you wanted to try that route.
Solution
Awesome thank you everyone I'm going to pick one up from STM. I'll look into a full silicone hose kit over the winter this isn't the first time a oil cooler line has failed and dumped coolant all over my garage.
