WES_393
DSM Wiseman
- 3,814
- 98
- Jun 6, 2011
Colo Spgs,
Colorado
How many threads are you going to start beating around the same bush? Get the correct supporting mods, or get rid of the 20g.
TSicktalon
Uhh yes, We just put this setup in my buddies GSX and obviously he has Wideband you cant use Link without it. I dont even have wideband or Link and im on 16lbs solid.
99ECLIPSEGSXDSM
You know what bro you should know that it is possible to run 30lbs on pump. we got an Evo who runs 44lbs on pump. just because you cant maybe you both should learn to build your DSM better before you run your mouth.
wow thats funny. Go ahead and run 44lbs on pump gas but dont come back and ask us why you need a new motor.
You're not supposed to disrespect Wiseman dude. These guys make the site worth being on, I can't thank them enough for devoting their time for free. And he is right you have made 3 different threads based on the same subject.
Take pictures of the turbo then post the serial numbers and we can tell you what it is.
Yes its two tone and its for a reason. Im known as Panda. Plus a paintjob here runs about 3 grand.
Theres your problem you got a dinkie T28 of im not mistaken thats one up from stock. And all my buddies who tune with Link say Lite doesnt tune past 20lbs so thats why. Your fuel setup with that turbo is just wasting gas.. Ironic you call me a noob when my car is more efficient. You dont even have a big turbo how can you give advice on one. Seems you belong in a Honda..
back to the topic AJAAYYEE if you have wideband and Link you can run the 20g with the stock pump and injectors.
Lite doesn't tune past 20lbs? Are you on crack?
All your buddies this, all your buddies that...
bro, shut up thanks. im asking for help. i will make a thread until i understand the answer.
That is not how this works. Research first. Being spoon fed this information and leaving you with the impression that you just need to bust out the credit card and throw parts at the problem is not going to help.
First word of advice - don't listen to this koafallenangel moron, and disregard your family mechanic.
Something to consider is that if you can't even figure out how to provide the amount of fuel to support a fairly pedestrian 48lb/min turbo like a 20G (not 48psi.. again should not have to distinguish between these two concepts) you have no business making such major modifications to your car yet.
Take a few months and study like a test is coming up. In the end you will save money, time and will be in a better position to learn how to tune.
You may disagree or take offense, whatever, but when you get to where many of us are and have a well sorted running car.. you'll be thankful.
I don't see where you even listed any goals for this car.. why did you settle on a 20G? What are you trying to achieve? As a hint.. 650s/680s would not be enough to let you take full advantage of a 20G.
LandSpeed
Just because you guys cant get a 20g to work with a stock fuel setup that doesnt make me a moron. Its a good tune that makes it possible. I know you need to upgrade the pump and injectors because itll limit your power. He if it was possible and here me and my friend has done so yet everyone cant believe it. Just because yall dont know doesnt give you the right to cut me.down. Youtube it. Its been done. Talk the trash you want ignorance is bliss. you dont know what you havent tried. you really underestimate the power of a stock 4g63t.
You aren't following the simple rules to use the forum, you type like a child, and you get mad at someone who knows things about cars when you don't? Brilliant.bro, shut up thanks. im asking for help.
I reported this post for sheer stupidity/misinformation. You obviously wear your ass as a hat, and you should really pipe down with the "my boy" nonsense and misinformation.back to the topic AJAAYYEE if you have wideband and Link you can run the 20g with the stock pump and injectors. if you want to change them by all means everyone is entitle to their own opinions and builds. I know it works and seen it because i put my hand into putting it together. Don't take advice from a guy who has a small turbo and obviously cant tune to run pump gas.
I don't get mad when somebody knows about cars when I don't. I know I don't know much but when I try and ask for help and you tell me things like I'm supposed to know them when I clearly said that I don't, it annoys me. Either you help or don't make me feel stupid. If you're gonna insult me for not knowing things atleast help me or don't post. And so far nobody is following the rules of this forum.
So 1 car runs good, in the opinion of an untrained nobody (you), and physics/mechanics are all out the window? Did you eat lead paint, or is this the result of too much Sbarro?You can send all the links you want to show me a car from a person who cant run a 14b it doesnt matter to me. All Im saying is there is a 20g running no problem with that stock fuel setup on pump gas. Also you shouldnt talk down about racers in Hawaii there is many quick and very competetive DSMers here that run very fast cars.
Mr Genesis thats not even a DSM you should talk. I offered advice to someone who asked if it was ok to run it and Im saying it is possible. peoplw who dont know run their mouth like childish kids. Also you drive a brand new car probably zero wrench time on it. I just fully rebuilt every little piece on my car so you have no right say anything. I prefer the smaller turbo because the fact its almost instant spool but it simply does not produce the hp needed to run under 10 in the 1/4. And this joke of a mod list would beat a stock genesis. you know how i know? i just ate it up last weekend at the tracks. Oh and remember this, i built my car, you bought yours.
