dsm-onster
DSM Wiseman
- 8,592
- 131
- Jul 11, 2004
Bloxom,
Virginia
It was overrunning at 5200rpms. It just hits so quick and hard that torque stear took my eyes off the logger.How were you overrunning your maft under 4500 rpms?
I've encountered maf overrun before. But I didn't expect it before 6K with a supposedly larger turbo. This turbo spools the fastest I've ever had experience with for the size. This turbo has compressor diameters comparable to a gt37 with turbine wheel diameters comparable to a gt35r.
. But, I've ridden in a well tuned DSM with a td06 20g with a 7cm turbine housing. It was an impressive machine. But so was an hx35 and a t3 stage3 50-trim. All used to over 400whp. And all had very similar spool characteristics. Both the garrett and holset flow more and were cheaper. I'm not knocking the 20g. It is dsm heritage. They hit VERY hard. They spool as early as the other two turbos I mentioned Bat what does a 20g offer that a 50-trim and bep housing doesn't other than accomodating stock oil lines?
