Resolved 1G Check Engine Light Help
mark 91 tsi
30
Jul 31, 2011
Inver Grove Heights, Minnesota
I recently purchased a non running 91 TSI. I had it delivered today and started trouble shooting the system. Here is my novice question: can someone post a picture of your check engine light on? I am assuming mine is not coming on and I need to look at the ecu, but having never seen the car running I am not positive what symbol I should be looking for. Thanks for your help.
Solution
Thanks for the input everyone. I took the ECU out, opened it up and found a bad/leaking capacitor. The corrosion was so bad that it ate through a trace on the board. I jumpered the trace and replaced 2 capacitors. After that I put the ECU back in and it started right up.
Steve - Thanks for the image. I assumed it was a common symbol or the actual words, but wanted to make sure.
Thing to look for is to see if the boost guage moves to "0" when you turn the key on. If not the computer is dead.
Right,
The bulb being burned out is only one possible cause of no CEL when you turn on the ignition. If the factory boost gauge doesn't more to 0 then the ECU's not running. High possibility of ECU damage but could also be a blown MPI fuse, blown Ignition fuse, problems with the ignition switch or wiring, etc.
Solution
  • For sale 2g NOS Sebring/Avenger floor mats
    These are slightly different shape than 2G mats but very close. NOS and still in plastic wrap. I...
    • MindBlowin03
  • Wanted 2g Anyone parting out a 2G?
    Need a few bolts that I'm missing for the rebuild, subframe and crossmember specific. Anyone...
    • Mahreeoh17
  • For sale 4G63 Mitsubishi # 284K00708 tach filter
    Mitsubishi OEM tach filter. With weather pack connector. Message 702-741-6987.
  • For sale 1g NEW ETS Street Intercooler for 1G DSM ( 4” Core )
    NEW ETS Street Intercooler for 1G DSM ( 4” Core ) $475 + shipping & paypal fees* these are...
  • For sale 2g 2g power window motors. OEM
    2g RH and LH power window motors OEM, $30 each. Sold the drivers and pass set of door switches...
