1G check engine light
mikey6981
May 9, 2010
El Cajon, California
so my cel comes on after the engine idles for a min or so, but doesnt come on when the engine is off but key is in the on position to check the cel. any ideas what this could be? the idle air valve does make a wierd grinding sound when i turn the key to the on position. anyhelp would be great...
Mike
Mike
When it comes on after the car idles, does it ever turn back off while driving?
First things first though, get it to a parts store that does free scanning and see what they pull up so we know what we might be dealing with...
no it never turns back off... and unfortunatly it is against some stupid law that says autoparts stores can't check CEL's
The parts store should be able to at least give you the error codes and you can work from there.
i just replaced the o2 sensor.
I dont know anyone around me that owns an OBD1 scanner... unless someone on here can let me use theres (might be a 12 pack for that someone)....
could a cracked exhaust manifold be a cause? or a bad idle air valve?
if it is its the dumbest law ive ever heard of
yes it is califorina law and yes i agree it is the dumbest law ever!!!
You can read the codes with a cheap analog volt meter, 12v LED, or 12v Piezo buzzer from Radio Shack.
The positive lead goes to pin 1 on the DLC and the negative to pin 12.
http://www.dsmtuners.com/forums/articles-tuning-ecu/319844-1g-code-reader-cel-code-reader.html
i have already done that.... for some reason wheni turn the key to the on position to check the codes nothing comes up... but a few seconds later the CEL comes on but it wont give me any codes...
i will go out right now and try it again and tell you guys if anything changes...
ok so i pulled code 31 which is the Detonation Sensor.... so now what do i need to do???
That would be your knock sensor if I'm not mistaken. But you could check the wire running from it to make sure it's not frayed, burned or damaged in anyway. If that checks out. How's your car been running? If it's been running fine you could just save some hassle and replace the knock sensor. If that doesn't work then I'd think you got some tuning issues.
the car runs fine imo but it just idles alittle funky and it also surges about 2 to 300 rpms at idle. but i do know that my BOV leaks. I used sea foam the other night ( through the vacum lines) and the cars rpms went up in stead of it stumbling like my explorer did I thought thats was alittle wierd.
can any one help me locate the knock sensor?
On the firewall side of the block in the middle under the intake manifold. The connector is attached to the intake manifold support and you can follow the wire to the sensor.
thank you all... would the knock sensor cause me to have extremely bad MPG's? and a rough idle?
so i think i know why i have bad MPG's..... i just found out i have 1000cc injectors.... now why in the hell would someone put 1000cc injectors on a mostly stock motor? now i could understand if it had a bigger turbo or something like that, but all this car has is a MBC and injectors...WTF!!!!
does anyone have anyone injectors for cheap that are a little smaller that i could run without a controller and still run 20 psi on?( i cant get the boost any lower for some reason)
Could probally post those injectors on your local Craigslist as well. Probally can get a set of 450's plus some cash maybe.
  • For sale 2g NOS Sebring/Avenger floor mats
    These are slightly different shape than 2G mats but very close. NOS and still in plastic wrap. I...
    • MindBlowin03
  • Wanted 2g Anyone parting out a 2G?
    Need a few bolts that I'm missing for the rebuild, subframe and crossmember specific. Anyone...
    • Mahreeoh17
  • For sale 4G63 Mitsubishi # 284K00708 tach filter
    Mitsubishi OEM tach filter. With weather pack connector. Message 702-741-6987.
  • For sale 1g NEW ETS Street Intercooler for 1G DSM ( 4” Core )
    NEW ETS Street Intercooler for 1G DSM ( 4” Core ) $475 + shipping & paypal fees* these are...
  • For sale 2g 2g power window motors. OEM
    2g RH and LH power window motors OEM, $30 each. Sold the drivers and pass set of door switches...
