11.95 @ 116 Holset hx40
dsmdizzle
105
Jan 7, 2006
Ogden, Utah
Last Friday Went to the Midnight drags at Rocky Mountain raceway. Trailered the car 100 miles there but was totally worth it. Straight off the trailer I ran an 11.95 @ 116 realized my injector duty cycles were high. Turned it down a bit and ran a couple of low 12's.
<object width="560" height="340"><param name="movie" value="http://www.youtube.com/v/Nph1CojqfIE&hl=en&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/Nph1CojqfIE&hl=en&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="560" height="340"></embed></object>
<object width="560" height="340"><param name="movie" value="http://www.youtube.com/v/JVYF6kexZLE&hl=en&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/JVYF6kexZLE&hl=en&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="560" height="340"></embed></object>
Care to share some info on the tune such as boost,timing,type of fuel?
Pretty good for missing a shift, too!
Nice!! I need to get a in cab cam I think they are awesome.
Boost was at 23 psi, stock timing map hitting 21 degrees in certain spots, richened up a bit 4k up, e 85 55psi fuel pressure.
That's pretty good for 23psi and the driving errors:p I'd be happy with that also knowing there is room for better times!
Thinking about the cranking up the hx40 some?
That is pretty good right off the trailer. I can't believe they don't make you wear a helmet.
I have to have a helmet and fire jacket and a roll bar just for that time at my local track.
Kind of stupid to worry about getting kicked out with a 16g, seems like your track is more lenient.
What holset hx40 do you have btw.
My duty cycles were upwards of 110% haha. I turned it down when i ran the 12's. Anyways I am going to get bigger injectors and turn it up to 32 psi and see if I can trap 130+ with the stock bottom end.
The 40 is an 8 blade off an 8.3l volvo.
23psi? That thing should... no, wait... DESERVES to be at 35+ psi without any question. At a minimum, you owe your car that much boost.
^After I posted I see you plan on turning it up. Just remember that 32psi is not a limit, but more of a goal. And that once you achieve that goal, you'll want more.
Nice times, but man does that turbo have more in it. I saw the post and thought hmm, those are more like HX-35 times, but then read how low boost you were, 60' bogged a litttle and missed that gear. Wow, Boost+ good launch+ good shifting = low 11's with bigger injectors. Oh and yeah that truck was movin! What a great starting point! 11's fresh off the trailer. Great job.
You mean more like e316g times ;)
Can we get some more details of your setup. I am really close to switching my HX35 for a HX40 everything I am seeing says they spool the same but the 40 has a lot more top end.
GOod run, can't wait to see more on real boost.
GREAT time for a first time at the track with the car!
The next guy I see get an e3 16g into the 11s after the first 2 passes gets a LOLlie pop from me. An 11 second e3 16g car is a big deal.
Where are you seeing that?
I agree. I'm sure the altitude is hurting him quite a bit also. It's probably at least a mile high at that track.
11's right off the bat with all those factors is pretty good!
