Getting closer to the 8s, holset hx40!
Yeah, I have it setup to the drivers front, and passengers rear. I had my tire pressure at 12psi and still didnt help. The car is put away for the season, already took off the slicks and stored them in my basement! May put the car on a dyno for shits and giggles, but not sure I even care what it makes.
I wish I could get a dog box that cheap!!! I work there and can't even get that good of a price. So that staging brake will hold you at the line pretty well until you're off of it even though it's only locking two wheels
mod list is up to date
I actually decided on copying your current mod list to the thread as it seems to change a lot and it would be good to have a hard record of what it took for you to go 9.12 and 158.5mph. :p
Others should follow suit when posting horsepower or track threads as no mod list seems to stay the same for long around here. ;)
talondave said:
Bolt-on Modifications:
Holset HX40pro 6 blade with BEP T3/ .70 ar 3" V-band turbine housing, T3 ERL stainless cast Manifold, Tial MV-S 38mm Vband Wastegate, FIC 1600cc Injectors, ETS 10.5" x 5" thick race intercooler, Curt Brown Spec 2g JMF Drag Intake manifold, JMF oil catch can, 3gal fuel cell, n/t ported throttle body with block off plate, Fuel lab AFPR, Fuel Lab "818" inline fuel filter, 6-an SS fuel line (feed and return), jmf rear bumper defusers, custom 4" intake, 4" K&N filter, Magnus heat bearrier gasket, Prothane Motor Mounts, n/t ofh, Tial Q 50mm bov, 3" side exit exhaust, Skunk2 Racing Cam Gears, greddy timing belt, fluidyne radiator with two slim fans, dual inline walbro 255lph fuel pumps, jayracing alternator relocation kit, Frontline fab tube front-end, Seibon oem style CF hood, ATI balancer!
Engine Management:
ECM Tuning V3, AEM Wideband, custom gauge cluster, with Autometer tach, Autometer speedo, Autometer Boost , Autometer coolant temp, Autometer Oil press, SD GM IAT, GM-style 4-bar map, custom build engine harness, and fuse box, 2g speed sensor.
Engine Internals:
Kelford 280/276 Cams, Magnus Head Studs, Fully built Darkside 2g head, with copper o-rings, 1mm Oversized SS valves, five angle valve job, Arp main studs, ACL tri metal race bearings (main and rod), mitsu mls head gasket, 6bolt block, BEK, OEM oil pump 90 straight cut gears, wiseco 1400hd 10:5-1 pistons, manley turbo tuff I beam rods with 22mm pins, Supertech dual valve springs, Ti retainers and locators, Supertech valve seals, Kiggly HLA pressure regulator, kiggly girdle, half filled block
Drivetrain Modifications:
PPG Shep Dogbox trans, PTT twindisc clutch, three speed Scatter shield, DSS HD driveshaft, upgraded 300m Tcase, ARP extended wheel studs, DSS pro series rear axles.
Suspension Modifications:
Custom valved D2 coilovers, Wilwood 4 piston calipers with scalloped rotors, 16" fd wheels wrapped with 4 Hoosier QTP 26-9.50-16 DOT dragslicks, 12 point chromoly roll cage with chute mount, stroud parachute, cnc staging brake.
What are all the plans for winter? And can the 1g get any lighter? I think it may be time for carbon fiber fenders,
Doors, hatch and some magnus wheel hubs. Save you another 200lbs there i think. That car will be so fun.
Wouldn't you like to know. LOL
Probably, but I think Dave's done spending money on parts regarding weight savings...unless he's willing to go on a diet, which I don't think is going to happen- Dave likes being tough enough to scare many large animals. :p
He's the only sub-6 in the 1/8th-mile car using a 60mm turbo....he's holding his own against a bunch of 42R's, 67mm PTE's, and 70+mm Borgs- so obviously the next thing to upgrade will be the turbo.
I think it may be time for carbon fiber fenders, Doors, hatch and some magnus wheel hubs. Save you another 200lbs there i think. That car will be so fun.
I think you should either drop some weight on your own car, or start donating if you want Dave to spend more money on his. :D
Thats the best part about being in the holset community. I'm hoping to my build for next season can start putting $1500 turbo setups to shame.:thumb:
Justin & Dave, I got the bep70ar HX52 pulled off my car and put the 'ol faithfull 40 back on. If you guys would like to get the T3 HX52 turbo just let me know, me and alex will gladly send it to you so you guys could try and do a test fit. Keep me posted cause we have no problem sharing the turbo with you guys.
Sometimes I wonder why I didnt just keep my hx40 with 14c2m housing.. Would have saved tons going single scroll 70 t3 seeing how Dave ,you and Alex are making great power.
Yeah, im pretty much done spending on the car for awhile, atleast for winter LOL. I have a huge enclosed gooseneck trailer I need to fix up and have ready for next season!
Might do a cf hatch in the future, but definitely not the doors or fenders!
We have a turbo in the works for the upcoming season, we'll see how it goes once the 40 hits the 8s.... Nothing will be switched till the stock hx40 goes 8s, I promise that!
Oh yeah, Justin I lost 20lbs since this summer, so maybe thats why the car trapped 158, compared to the 154 earlier this year!!! LOL
CeeDawg, the hx40 is the best for all around contendor turbo. Single throat turbine housings are indeed awesome, I've had didveded befor but have never had a true divided turbo header. It works and I'm totally happy with the Holset HX series. Just swapped out the big 52 for the little brother 40 (LOVE the way the 40 sounds) its. The damnest thing tho, I swap out snails and my valve cover gasket deceides to spring a leak....
Sometimes the DSM game is indeed a curse, it never ends does it :) ....
Now I feel like a new DSM guy but what is the CB Spec intake diff from the Race one
No look under the drag manifold there is a CB spec drag mani
" The "Curt Brown Special" 2G Drag Intake Manifold is available for no extra charge, it consits of a longer runner length ideal for 1G cars running a 2G head. Also available is a RWD version of this manifold for no extra cost as well, perfect for the custom 4G63 swap into a rear wheel drive vehicle. If purchasing one of these versions online be sure to specify which version during checkout in the "Comments" section."
Anything special done to the rear in this car?
Nope nothing, stock with unknown mileage.
Less then a month away, and the car will be ripping up the track again! Im getting excited.
What ignition setup are you running? Stock coils with NGK 7-8 plugs or a c.o.p with Cdi box? I'm curious with the compression and boost you run.
are you planning on going to IFO at the end of the month?
Yes, the one at capital on the 30th.
Im running stock coil pack, with ngk wires and ngk 7 plugs.
  • Wanted 6 bolt NT water pipe
    • chrisman287
