LaserRS92
Supporting VIP
- 322
- 35
- Aug 14, 2008
Fort Wayne,
Indiana
What exhaust manifold to head stud kit is that? I like the blue hue tying into the rest of the bay. That's an impressive manifold and turbo combo you have!
Thanks! I got a titanium exhaust manifold stud kit from JD Customs in the burnt finish.What exhaust manifold to head stud kit is that? I like the blue hue tying into the rest of the bay. That's an impressive manifold and turbo combo you have!
haha Thank you!I’m just going to say that thing is fu&#ing gangster! Love it
I will get some photos of everything during installation I'm sure, but here's some cage update photos and also some photos of the rear subframe/diff/axle score!
. We'll see though!Was wondering that too - what's going on Christian? Hoping you'll also chime in here too:Any updates?
. Either way, looking forward to next year's Shootout!Hey Guys,
Sorry I haven't been on top of the updates. There's a lot that has been going on on my end. I appreciate the kind words @Ludachris , things have been much different.
I'm going to kinda skip over a lot and just jump right into the track time at the 2026 Shootout. I will come back to parts updates that happened before the 2025 shootout in later posts (like them beautiful Kiggly planetary gear set).
The car survived the dyno, so it was time to get the thing ready for some passes. My only real goal was to get the car to Norwalk this year and get an 8 second slip. We did just that. I had a lot of help with my friends, without them this wasn't going to be happening. So thank you Scott, Paul and everyone else.
Car's first hit off the trailer after a couple years and really no testing went 9.0 at 155. Second hit was our 8.8 sec pass at 159 mph. We pulled the plugs after that run to see what timing looked like (it wanted more!). We added boost, timing, and tried for a better 60'. I feel like the car would have had a 8.50 in it.
First pass 9.0:
Second and last pass of The Shootout, 8.8 at 159 mph:
Also, here's a little LTA Recap video that Scott put together:
I believe we hurt something while getting more regressive with the 2 step after our 8.8 pass. We really need to get this car to 60' better. It happens. We yanked the head over night, and I was expecting to see damage, but there wasn't much. Leak down test before we pulled the head told us exhaust valves were not happy on cylinder 3 I believe it was. Poured some water in the chamber when the head was pulled and it was leaking pretty bad out of those exhaust valves. We called it a weekend.
I've already got the head fixed up and ready to get things back together. I will be making some changes to try and keep valves happy. Unfortunately, I'm not 100% sure what caused the damage. One theory we think is the distribution of nitrous using the single nozzle. I will be changing to a direct port dry nitrous system to make sure distribution is consistent between all cylinders. I've also made a change to Kiggly's race only valve springs, as we are targeting higher boost levels on M1 for next year. I'd really like to get back into the 1/8 mile local no prep stuff again for 2026.
It was a great time at the Shootout as always. Thanks to everyone that said hi and helped out, it's much appreciated. With how the rules are looking for 2026, we may either have to make a turbo change, or donate to the Q32 pot. Either way, looking forward to next year's Shootout!
As always, thanks for checking this out!
-Christian
Man I wish I could have made it out to Ohio this year, looked like a great time as usual.
With any luck we can line up in Q32 together
I am here, I promise. I will get a proper 2026 Shootout Post at some point!Been quiet in this thread for 2026, Christian. No updates since last year. Looks like we lost another one to Zuck.
I see you got one of these fancy graphics though, so congrats:
but all was good. It was actually a good thing this happened. I looked back at the logs, and saw my IDC were wayyy higher than expected. Although fueling was super rich, I had a feeling the secondary rail’s 2200s weren’t going to be enough for the boost I wanted to be able to get to (I want to know I have fuel for 75-80psi). I decided to replace the secondary rail injectors with a second set of Alpha Injector 2600s- So now there’s TWO 2600cc injectors per hole. (And I still don’t think it’s enough for what I want!!!)
.That's what I'm talkin' about. Nice update!Hey All!
As pointed out, there hasn’t been many updates over 2026 season. I got to say though, I haven’t really done too much to the car since the 2025 shootout. Tyler at Force fixed up the cylinder head’s valves, installed some fresh Kiggly race springs, and that seemed to have fixed up the issues we created at the 2025 Shootout.
In this post I’ll focus on the changes and will have a follow up post about the 2026 Shootout.
The major changes from 2025 included the switch to M1, Direct port nitrous, and getting weight out of the car
I started with the change to direct port nitrous system. Although I was never able to prove the single nozzle caused or aided in the valve damage, I figured an even distribution of nitrous among cylinders would probably just be the best approach. So, I learned what was needed to bend and flare SS tube, and well here’s the result.
View attachment 800657 View attachment 800658
I was happy with how it turned out. I learned to make sure you lube SS tube a bit before flaring, and make sure you have a tool that is able to flare SS. At times I found it kind of tricky to get everything sealed up with no leaks but eventually got there. Currently I believe I have .026 jets in each nozzle, so about 100 shot worth of nitrous when duty is set to 100%.
Once the intake was back on and the new nitrous lines sorted, it was time for the switch to methanol. It was a fairly straight forward conversion to M1. I had the car on pump 93 so I feel like I flushed the system 28 times to make sure it was ALL out (I only flushed it maybe 4 times- twice with E85 and then twice with M1). Once I felt good about getting the 93 out, I got some ECU adjustments from Kevin to get it fired up and driving on M1. Took it for a quick little street pull that was supposed to see about 10-15ish psi? That turned into a quick 48psibut all was good. It was actually a good thing this happened. I looked back at the logs, and saw my IDC were wayyy higher than expected. Although fueling was super rich, I had a feeling the secondary rail’s 2200s weren’t going to be enough for the boost I wanted to be able to get to (I want to know I have fuel for 75-80psi). I decided to replace the secondary rail injectors with a second set of Alpha Injector 2600s- So now there’s TWO 2600cc injectors per hole. (And I still don’t think it’s enough for what I want!!!)
View attachment 800660 View attachment 800659
Next up was a diet for the car- I’m next. I’ve had some Carbonetics carbon fiber doors, sunroof plug, and a forged carbon hatch that needed to go on. Unfortunately, I never weighed the car before installing these parts, but I did my best at trying to get weights and differences as I uninstalled the OEM parts and installed the carbon parts.
I started with the hatch. I had Paul install a FAL polycarbonate window on the sweet, forged carbon hatch and he did a GREAT job. I cringily (new word?) put the hole in the hatch for the puke tank vent stack and finished it off with the trim ring I had on the OEM hatch. I did not enjoy doing this, but it turned out pretty good. Lastly, I applied my DSM TUNERS and LTA decals to finish it off!
OEM Hatch w/ 2gb high rise spoiler & OEM glass: ~68.8lbs
CF Hatch w/ FAL window: ~24lbs
Difference of ~44.8lbs
View attachment 800661 View attachment 800662 View attachment 800663
View attachment 800665 View attachment 800664 View attachment 800666
View attachment 800669 View attachment 800668
Next was taking out the OEM sunroof assembly and installing the Carbonetics CF sunroof plug.
OEM sunroof assembly: ~29lbs
CF sunroof plug: ~5.9lbs
Difference of ~23.1lbs
View attachment 800671 View attachment 800670
Lastly, the CF doors. This was my first time taking doors off, these are some heavy mfs! I took weight measurements of the OEM doors without the doors card and without the OEM glass, so I tried the same with the CF doors. I cannot remember if I took weights of OEM doors with or without the tracks and window motors though… I also added some Angry Aero side mirror delete covers for those drag racin' days!
OEM Doors w/o glass: ~70.6lbs
CF Doors w/o glass or tracks: ~12lbs
Difference of ~58.6 X 2 = 117.2lbs!
View attachment 800673 View attachment 800672
View attachment 800674 View attachment 800675
SO, a total weight difference of about 185.1 lbs, NOT too shabby!
The carbon fiber parts were essentially my Shootout “scramble” this year. Since the car no longer fit Street eliminator class, I decided instead of purchasing a smaller turbo and slowing things down, I’m getting the car into the Quick 32 class. So, I got the car into Q32 trim and took out a good amount from the interior. Passenger seat, rear seats, most of the interior plastic trim, BUT I had to keep the dash, center console, and some carpeting… I just like how it all looks TOO much to take out. Anyway, I had asked the Shootout page if they would be able to have scales open for a day, I’ve always wanted to weigh the car and they never have scales open. They agreed and had them open Friday. Total weight of the car WITH my big back in it came out to 2,770 lbs just after a hit, so about 2,525 lbs I’d say without me in it. Pretty happy with that, and I do think I can find a bit more weight in the car to cut. It wouldn’t hurt for me to drop 45 lbs either.
Anyway, my apologies for lack of posts and updates. I will get a 2026 Shootout post up, and also my brief no prep outing I had a couple weeks after the Shootout.
Here's a little tire wrinkle teaser for the next post:
As always, Thanks for looking!
. So this time everybody came out — Scott, Paul, my wife and kids, my brother, nephew, mom, and the in-laws. My father-in-law is also a big-time car guy, so he was itching to help load the car up and head to the track.
. I cooked for the family, hung out with everyone, and we got to watch some great racing.
