dwb
- 1,568
- 1,084
- Sep 9, 2021
Broomfield,
Colorado
Since your intercooler/piping is all aftermarket according to your build, I doubt you have another port, but always worth a look. That would be ideal for boost control but maybe not feasible right now. Eventually you could tap a port into your intercooler piping somewhere.
BOV should have a larger diameter source than the P port on the TB. Save P port for when you get a boost gauge, preferably sooner than later since you're already running higher than stock boost. Even an inexpensive boost gauge and single A-pillar pod would be better than the stocker.
If it were me, I'd move boost controller to port E on the throttle body. This port is boost only, which is what you want for boost control. Then move the BOV back to the stock location on the intake manifold port.
