4G63 Head build ups, 6 Bolt, 7 Bolt
BogusSVO
5,886
337
Jul 1, 2009
Pensacola, Florida
Mitsubishi 4G63 Head Build
I am starting out with 8 heads.
5 are 1G 6 bolt and 3 are 2G 7 bolt
I think one may be a Hyundai head
Some of the heads have been through a machine shop before.
Some base information has been gathered.
The heads have been disassembled, thermal cleaned and glass beaded.
Most of the heads have the oil galley plugs removed.
All heads will be fitted with +1mm oversized valves
7 Heads will have installed BC1100 valve springs
3 Heads will use BC Ti retainers.
Some heads will receive new seats and/or new guides
All heads will receive Vition valve stem seals
Oil port mod #1 will be done
http://www.dsmtuners.com/forums/newbie-forum/341028-4g63t-head-oil-port-mod.html
Front view
Exhaust side
Intake side
Thermostat side
Measuring head thickness
http://www.dsmtuners.com/forums/cyl...how-measure-4g63-cylinder-head-thickness.html
New head thickness is 5.200
AREA Min thickness is 5.185
Mitsu factory allows a combined total .007 milled from head and block
Head #914 (This number was stamped by another machine shop)
1G
head markings G6/8
10mm exhaust corner studs
Oil port mod has been done
(I-F) Intake-Front 5.191 (E-F) Exhaust-Front 5.187
(I-R) Intake-Rear 5.188 (E-R)Exhaust-Rear 5.182
Head #200 (This series of heads will start with 200 and count up)
1G
Head markings 2.0/8
8mm exhaust corner studs
Oil port mod NEEDS done
I-F 5.198 E-F 5.197
I-R 5.196 E-R 5.194
Head #201
1G
Head markings G6/1
Oil port mod done
I have rebuilt this head once before
Head will receive 16 bronze guides
16 new seats
Head has been ported
I-F 5.190 E-F 5.190
I-R 5.190 E-R 5.190
Close up of guides and seats removed
http://www.dsmtuners.com/forums/newbie-forum/341218-how-change-valve-guides-4g63t-head.html
http://www.dsmtuners.com/forums/newbie-forum/341297-how-replace-seats-aluminum-head.html
Head #202
1G
Head markings G6/5
8mm corner exhaust studs
Oil port mod done
Needs 8 exhaust guides
I-F 5.167 E-F 5.166
I-R 5.166 E-R 5.165
This head is well past service limit, but can be used with a thick head gasket and adjustable cam gears, or work well on a high compression non-turbo engine.
Head #203
1G
Head markings none/smooth
(I think this is the Hyundai head)
Oil port mod done
I-F 5.188 E-F 5.194
I-R 5.188 E-R 5.194
Head #204
2G
Head markings G6S/7
Oil port Mod done
Has broken exhaust manifold stud
I-F 5.200 E-F 5.199
I-R 5.200 E-R 5.199
Head # 205
2G
Head markings G6K/3
Oil Port Mod Done
I-F 5.191 E-F 5.192
I-R 5.192 E-R 5.190
Head #206
2G
Head markings G6K/1
Oil Port Mod Done
I-F 5.195 E-F 5.195
I-R 5.196 E-R 5.193
Some of the Parts I will use
I dont know.... Do I have one of your heads?:hmm:
I just recently bought 2 more core heads, (1) 6bolt and (1) 7 bolt, to get cleaned up and to the point of these. So I will have a couple of spares in the shop
So, to get this right. Your taking cores and rebuilding them and sending them out? Whats the going price?
No most all these heads I am building are for my local customers.
If you need a head, Check with the supporting vendors Like JAM or SIM
I love how your posting the details specs. I wish more vendors would do this sort of thing. I take if we sent you a head you'd do some work on it for a modest fee? (dependant on the work obviously)
RipperXX....... Thanks! I am NOT a vendor here on tuners. I do have a samll machine shop and deal with alot of the local DSM crowd.
If you need a head done, I would check with one of the supporting vendors here! They support DSM Tuners, so the members need to support them!
I post the info so members will know what to look for and not have an issue if they go to there local machine shops.
Even though this build thread is "carless", I love it! It's interesting to read about.
And thank you Mr. BogusSVO for all your incite on the forums. I've used your knowledge more then once now.
Geesh A year and a half has past, since I updated this... I found some build notes and thought nI would add the finish specs.
Head #200
Ended up with cast replacement guides, +1mm OS valves, vition blue seals
Head thickness after surface is 5.195
Combustion chamber 47cc
Head #201
Bronze guides, all new seats, Vition blues seals
BC100 spring kit
+2mm os Valves
Head thickness 5.181
Combustion Chamber 42cc
Head #202
Has bronze guides, Used +1mm os Valves, Vition blue seals
Head thickness 5.162
Combustion Chamber 45.5
Head E80
7 Bolt
Head thickness 5.191
Combustion chamber 46cc
6T valves
Cast guides
.500 head bolt holes
BC1100 springs w/ stock retainers
Head E81
Head thickness 5.189
Combustion chamber 45cc
6T valves
Cast guides
BC1100 springs w/Stock Retainers
Head E83
7 Bolt
G6K 1 Casting
Head thickness 5.170
Combustion Chamber 44.25
6T Valves
Cast guides
Head 932
7 Bolt
head thickness 5.192
Combustion chamber 44.5cc
Std SS Valves
Bronze guides
Dual valve springs
