eclipse_16g
- 274
- 24
- Oct 8, 2008
Connecticut
This is the Build Thread for Barn Find -1990 Eclipse GSX. Reply below.
I actually bought a full gates timing belt kit that will go on eventually, along with head gasket and studs. For the first start though just to make sure the engine is good I had planned to inspect the belt that's on there now, and replace it if need be. I appreciate the recommendation, and who knows maybe I will just replace it prior anyway.I wouldn't even attempt to start without a fresh timing belt. Its just too old.
I tested the CEL about a month ago, no codes stored. I should check it again. Yes visually checked both ECU and MPI relay, pictures should be above.Does it have a check engine light? Does the check engine light come on at key on then go out after 5 seconds? Have you visually inspected ecu?
