007jimmy
- 1,617
- 205
- Feb 27, 2012
Levittown,
Pennsylvania
I have a 20g compressor wheel with the anti surge housing and the CHRA/turbine housing are from an MHI B16g. Is it worth my while to have the turbine housing machined to accept the TD06H turbine or just keep the TD05H? The flapper is welded shut and ill be running a 38mm wastegate off the manifold. 1000cc injectors and link to tune with. 22-24psi max, 93octane and the rest of mods are in my profile. Turbo and injectors are not going to be installed till I figure this out. Thoughts?
Thanks in advance.
Thanks in advance.
That was a clipped Big16 also.
