Which timing components on a hybrid(6 bolt block, 7 bolt head ??
Talyn
443
19
Jun 10, 2012
Pittsburgh, Pennsylvania
Title says it all I am replacing the timing belt and related components, I have a hybrid swapped car(I did not do the swap myself) and am unfamiliar to the differences between the 1g and 2g 4g63s.
Do I just get everything for a 1g car?(If so any particular year?) or do I have to get some parts for a 2g car? Also I have a rather substantial oil leak from the side of the timing cover is on(I have no idea where the leak is, as it gets on the belt and flung everywhere) Any particular way to tell if an incorrect gasket was used? And which gaskets should be used?
Ok, I thought as much, also, my timing cover was rubbing on my power steering pulley, any idea why? I suspect it was supposed to be clearanced, or is the wrong one for a hybrid?
