6 bolt block, 7 bolt head, 6 bolt cams, which timing belt?
infinite_kaos
194
Nov 17, 2008
Victorville, California
Did a search, couldn't find a result. Just a quick question with hopefully a quick answer.
I'm doing a rebuild on my 92 talon tsi awd. I'm using the 6 bolt block, 7 bolt head, but with the 6 bolt cams and gears.
There's a difference online for the timing belts, so I'm not sure which belt I'm supposed to get, I'm leaning more towards the 6 bolt belt, let me know what you guys think.
If your using 6 bolt cam gears like you said, then you only need a 6 bolt t-belt. Be sure to crank it over a few times by hand and make sure everything still lines up. Just curious are you using a 1g or 2g intake manifold?
Goodyear Gatorback Timing Belt:
Part Number: 40167
This product fits the following vehicles - click on a vehicle to see detailed engine information.
Dodge back to top
1989 - 1990 2000 GTX
Eagle back to top
1991 - 1993 2000 GTX
1990 - 1998 Talon
Hyundai back to top
1993 - 1995 Elantra
1992 - 1998 Sonata
Mitsubishi back to top
1990 - 1999 Eclipse
2003 - 2006 Lancer
1989 - 1993 Galant
Plymouth back to top
1990 - 1994 Laser
They are all the same
I'm getting all my parts from the dealership, since I get over 50% off the prices. When I look on mitsu's website it shows different numbers for the t belt.
I'm using a 2g manifold btw, with the 1g throttle body. I'm just going for a good street build.
For some reason I can't see the part numbers from my phone (I'm at work so I use my phone for internet, which is how I'm posting this LOL)
But I can see that it shows different years, from 91-92 then from 92+
So I'm assuming they're different numbers, also that I saw different numbers last night.
Victorvillemitsubishi.com
Top right hand under parts dropdown, then order parts. It'll give you the option for year/make/model
