which be better a hx35 or 16g turbo..
DoggTalon
69
Jun 13, 2012
Mankato, Minnesota
I was wonder what turbo be better hx35 or 16g turbo and I was what I all would need to one of these setups 95 talon tsi
I guess my goal is about 400 hp something like a weekend and maybe drive little bit on weekdays car to have fun on...
I have a turbo sitting around I bought with some parts buy don't know what it is and the numbers on it isTd05h and 491 780-1420
What would be theSuppporting mods, boost and tune for a street car
You could find a happy medium by running the EVO III 16g with the larger FP 8cm turbine housing. This would give you some more top end to play with :D You can also upgrade the turbine completely and go with the MHI TD06 or TD06H inside the 8cm housing.
Right now... I have cold air intake, 3 in exhaust and link, intercooler, walbro 255 sitting that needs to be put on oh and that... so turbo is really 16g not a ebay one or anything... what other parts would I need like injector and maybe a boost controller and would headers help out does or stay with stock one
also a upgraded fuel pressure regulator for the 255 when you install that, skip headers for now unless $$$ is on your side, if you go cheap on them they will be just that cheap and weak guaranteed to crack, injector upgrade too
get that wideband first though
I got a 16g and its great!
If u wonder what is why u are noob in this, so go for the 16g...
Shop around as there are other options than just those two turbos. Your best bet would be to do a bunch of research and decide what kind of car you are looking to build. Don't pick a turbo until you've figured out exactly what your plans are.
huh?
exactly :thumb:
and also what supporting mods are needed and make sure your maintenance is good to go first
like everyone said, depends pm goal and get supporting mod to get the most out of it.
