Please Support Kiggly Racing
11 sec. 500+hp fwd
Ownership Status
Currently Own
Mitsubishi Eclipse GST
Turbo Type
50-trim
Drivetrain
FWD
Build Type
  1. Street
  2. Drag Race
Fp intake with k&n filter, jb black with fp ofh feed line, ported fp exhaust manifold, ets 3.5" short route intercooler kit, , stainless 6an pump to filtèr line, 6an filter to aem fuel rail line, aem fuel pressure reg. firewall mounted with stainless 6 an line, 3" megan exhaust, stm rewired walbro 450, rewired inline walbro 255, fic 2150s with plug n play pig tales, fuelab 848 6an fuel filter with check valve and 40 micron screen, greddy type s bov, intercooled nitrous, punishment 02 housing with tial 38 and 3" pr down pipe, fluidampr harmonic damper, Magnus smim with ported nt tb, Calan catch can, mishimoto aluminum radiator & hoses, jmf deluxe coolant resevoir, 2 mr. Gasket 12" 1400cfm push fans, seibon vsll carbon fiber hood with carbon fiber aerocatch latches, moroso battery box, kill switch, 2 150 amp breakers, 150 amp in line fuse, 160 amp single wire saturn alternator with Jays steel relocation kit, 2 gauge power wires from kill to starter and alternator, 4 gauge from distribution block to fuse box.
Mods-Engine
2.3 stroker kit, .040 over, eagle h beam rods 9:1 wiseco pistons perma torque head gasket all arp bolts, balancing shaft elim. kit, stage 3 magnus head with gsc s2 cams and fidanza adjustable gears
Mods-EMS & Logging
Ecm link v3 full, autometer 30psi boost gauge, innovate mtx-L a/f and innovate dual oil temp / psi gauge, omni 4bar map, gm iat, plug n play sd cable, IR boost control solenoid, greddy turbo timer, tuned by my1gdsm.
Mods-Drivetrain
Sbc ssx with ceramic clutch,
Competition Clutch Street Chromoly Steel flywheel, "tre" stage 3 with quaife lsd and taller 5th, b&m short shifter with bearing cable end mod, stainless steel line from master to slave, competition Clutch Forged Steel Release Fork & Pivot Ball:
Feal coilovers, avid 75 mounts, all polyurethane bushings, upper and lower strut bar in rear and upper in front. Rear camber kit and 17" enkeis with gforce street tires. Stock 16" rims with hoosier qtp 26x9.5-16's
Parts Wishlist
Awd
Background
Owned for 10 years and haven't even put 10000 miles on it. Well over $20000 though.
1/8 Mile E/T
7.609
1/8 Mile MPH
98.51
Timeslip Photo Link
Dyno HP
606.5 whp
553.9 lb/ft
Dyno Type
DynoJet
Dyno Sheet Photo Link
Dyno Shop Name
dyno edge albuquerque nm
Dyno Session Details
E98 33 lbs no nitrous.
97_4g63t
Comments
3
More in 2G DSM
Share this Vehicle
