Please Support Rix Racing
Street Build 98 Spyder GST (AWD swap)
Ownership Status
Currently Own
Mitsubishi Eclipse Spyder GST
Turbo Type
GT42 Variant
Drivetrain
AWD
Automatic
Build Type
  1. Street
  2. Drag Race
Bosch 044(x2)
-10an PTFE fuel feed
-8an PTFE fuel return
FIC 2150cc
Fuel Lab AFPR
Fuel lab 75 micron SS fuel filter
Earl's 75 micron pre pump filter's
Borg Warner s475 w/race cover
JMF Top Mount
4" aluminum exhaust w/vibrant race muffler
Avid racing engine mounts (90A)
Tial Q
Derale 15660 oil and trans cooler
Davies Craig EWP115 water pump
AFCO radiator
NGK copper BR9ES plugs
Spark Tech COP
Dynatek ARC-2
ETS 5" super short route FMIC
Mods-Engine
Ported 1G head
Magnus cast intake manifold
K-Tuned 90mm throttle body
GSC S3 cams
BC cam gears (+1/-1)
Kiggly race only valve springs
Kiggly HLA
ARP 625+ headstuds
RnR aluminum connecting rods w/L19 bolts
Wiseco HD 8.5:1 cr pistons
Fluidampr pulley
EVO 9 OFH
Straight cut oil pump gears
Mods-EMS & Logging
ECMLink V3
AEM (wideband, oil pressure, oil temperature, -30/50 PSI, volt, trans temp)
Davies Craig Digital water pump controller
Mods-Drivetrain
Precision Industries billet #7 Torque converter
Kiggly front clutches
John Deere Hy Gaurd fluid
Automatic swap
TransLab shift kit w/max pressure
Forced Four shift box plus
AWD swap
Frontline Fabrication rear diff cover
DSS 3.5" driveshaft
Solid rear subframe and diff bushings
KW V3 coilovers
Solid top hats
Front sturt bar
Mickey Thompson Drag 26x8.5x15
Rota slipstream 15x7 +40mm
SS brake lines
Odyssey PC680 battery
Parts Wishlist
Paint
Background
Bought the car on a whim.
1/8 Mile E/T
7.608
1/8 Mile MPH
98.110
Timeslip Video Link
Watch Video
Timeslip Photo Link
Timeslip Details
Second day at the track as AWD on base retune. Snapped an axle and broke a wheel hub after this pass.
renovatdkitchen
Comments
4
Rating
5.00 star(s) 1 ratings
More in 2G DSM
More from renovatdkitchen
Share this Vehicle
