Whats that things name!
Ces4rDSM
119
6
Feb 2, 2019
watsonville, California
Hey, im trying to figure out what component this is. On top of the intake theres a metal box connected with all these little tubes that go in different connections with air paths, im disconnected brainlessly when doing hg change but in order to set up right I need to know what its called XD rip. Welp.
i have no idea what you talking about or if your talking about the air intake or the intake manifold.
hopefullly this will help
Lol the emojis, Thank you for your help good sir.
PS still looking for more help, there's little tubes that connect to the top side part of the intake and the intakes rear side what do they serve for ?
Diagram 2 number 22 they're little rubber tubes.
I am assuming you mean the EGR tubes? In which case that would be your throttle body
Here is mine with color coordinated silicone hosing because I am OCD about trivial things
Pictures are worth a thousand words
Thank you, yeah with our 20 year old cars the rubber was starting to crack and the colors had long since faded. So if I understand correctly you disconnected the hoses and now are looking at where they go?
There should theoretically be an OEM sticker that says EGR Diagram under your hood that gives a basic idea of where hoses go, but a better diagram is found in the Haynes manual which you might be able to find online if you do not have a physical copy
If I were near my car I would take pictures for you, but alas I am away atm
@BLACK'98DSM on the 4g63t all the hoses connect to a bunch of tubes weld to a bracket (like a tubing distribution block) that bolts to the back of the throttle body. Looks like a gaggle of short brake hard lines. Tubes is correct.
@BLACK'98DSM on the 4g63t all the hoses connect to a bunch of tubes weld to a bracket (like a tubing distribution block) that bolts to the back of the throttle body. Looks like a gaggle of short break lines. Tubes is correct.
I wasn't saying that he was using the incorrect term. But thanks for your input
  • For sale 4G63 Groden alum rods. Set of 4 with ACL bearings
    Groden aluminum rods. Set of four. 22mm small end. With ACL race rod bearings. Locating...
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
