2G What missing for 450/500whp target?
gsx tuningart
80
3
Jan 18, 2005
Viterbo, Europe
Hi guys,
my 95 gsx have around 350 hp at 15/16 psi boost. But max output from turbo is 20psi and i have the same hp.
i don't know if i need of something more .
Any advice is appreciated
This is the list of my built:
6 bolt block
Stock crank
Eagle Rod
Arias pistons 86,00 8.8
Arp head and main stud
King xp Rod and main bearing
Fidanza aluminium flywheel
Act 2600 pp act 6 puck disk.
Competition clutch fork
Cometic head gasket
7 bolt ported head
Magnus intake Manifold
1g throttle body
1g cas
Cams hks 272 272
3g lifters
Gsc valve stem seals
Fidanza adjustable CAM gear
720 injector
Aem fuel rail
Aem fpr
Walbro255 rewired
Dnp exhaust manifold
Mvr44 Tial
Greddy fv recirculate
2,5 piping and fmic
Aem Wide band
Omnipower 3bar map sensor
Ecmlink v3
Turbo : Garrett TB 03
C.wheels ex.68,9mm in.48,8mm
T.wheels ex.48,7mm in.58,9mm
Bullseyes housing
3" downpipe and cat back
Mbc
This is was thinking, but I do not have enough knowledge of the turbo.
Many options out there.
My car is fun, the turbo is fast and push very well, but I need of more power, so I would want a good turbo, but not much bigger.
someone told me for 68hta, another for gt3076, another for red fp.
I'm really confused
I also say injectors is your main issue, turbo is also needing a help as its tiny! also maybe your tune needs adjusting.
Also please reply in english to get more answers, while we do accomodate for not so good speaking english folks its far easier for us to reply and willing to help when its in english even google translate it in, thanks
Questo è stato io pensando, ma non ho abbastanza conoscenza del turbo.
Molte opzioni là fuori.
La mia macchina è divertente, il turbo è veloce e spinge bene, ma ho bisogno di più potenza, quindi vorrei un buon turbo ma non molto più grande.
qualcuno spinge per 68hta, altro per gt3076, altro per rosso fp.
sono veramente confuso
English man... we speak American in the US
Wait,
how you see my answer?
italian? english?
maybe i have a problem with my phone setting.
Sorry!
I have changed my replies in english, sorry again!!
They was coming in your language, Italian gatering what you just said,
Its now showing in english, so we can see it better now, thanks
I'm really confused
Well since you want 400hp a 16g would be hard pushed but a 20g would be good if you can get one, anything non mitsu flange based is going to cost alot more due to needing a new manifold and perhaps o2/DP mods
Anyway , 1250 fic is in my plan.
I have a good offer for this setup.
Punishment headers and O2HOUSING
Gt35 and Tial.
Maybe it's too big for me?
We dont have headers, thats non turbo talk, we have a manifold,
That kit will be fine but you will endup pushing the 1250 aswel eventually, think long term, build it once and build it right, but for 400 the 1250 will do, after about 500 ish they will start to be too small and future plans always mean getting more power LOL
Ok, manifold! Sorry!
This is the point.i think for the future,and i need of more info about this.
Whit my built+ 1250 fic + fp red ,i can make 450 and i don't need of more new parts right?
if i got gt3076r i need of some work like manifold etc.
I don't know if i can use my bullseyes housing and my manifold for this turbo.
If i bought gt35 setup, i have more power,but i need of a lot new parts?
i mean ,
stock 2gMaf is enought?
walbro 255?
i need of speed density set up?
This is my problem!
for 450 1250cc is fine, boost depending aswel, the tg35 will be fine on 1250 aswel if its within its boundrys, check out FIC injectors site to check specs and use their flow and hp charts available to help you further,
I am looking for a GTX30/35 longterm and i was going to look for close to 1650 or close to 2150 injectors. so for now i think you are very safe.
a 255 will be fine aswel so no need to adjust that yet. read through here aswel for help http://www.dsmtuners.com/threads/basic-horsepower-ugrades-2g-4g63t.480196/
since you have ecmlink you can get an evo maf with harness adaptor or go SD, its your choice but for now your maf,everything is searchable and dta aquired on here so please do search aswel as you will learn alot more this way
we can advise aswel and hope your plans go well, just remember to do it right the first time and not half ass it or it may cause issues and break
I'm really confused
Whatever turbo you choose if it isnt rated for the airflow you need for your hp goal then obviously yiu wont make it. Each turbo has different characteristics. A better question is what do you want the car to do, not how much hp. You could make 1000hp but the car isnt any fun because of how you usually drive it.
You right!!
so, i can't explain my feel about the car that i want, but i try .
i have a friend with a BMW 335I 3000v6 twin turbo and his car is awesome.
this is the dino chart.
i would want my car as close to this.
Is this possible?
What i need for this target?
LOL here is some conversion soup for us American English speakers.
"couple" is torque
  • Wanted 6 bolt NT water pipe
    • chrisman287
