Street Build DD 68hta
Ownership Status
Currently Own
Eagle Talon TSi AWD
Turbo Type
16g
Drivetrain
AWD
Build Type
  1. Street
Turbo/Exhaust:
FP68HTA V1 w/ 8cm housing (ported) and billet 68 mm compressor wheel
Tial 38 mm MV-s wastegate
FP race manifold (ported)
PR o2 housing w/ dump tube
PR 3" downpipe
Apexi N1 exhaust
Intake:
Evo III intake manifold
Evo III throttle body
Calan VS3/Eaton Motorworks catch can
Hal's billet 7075 vented oil cap
FP intake pipe w/ 9" filter (non-recirculating)
GReddy Type-FV bov (non-recirculating)
Ebay FMIC (Godspeed)
Fuel:
FIC 1200cc (High-Z)
Walbro 450lph
Evo III fuel rail
-8an feed, -6an return
Fuelab 858 filter w/ check valve, 5" Element 40 micron/SS filter
Fuelab 545 fuel pressure regulator
Cooling:
Mishimoto X-line radiator
Mishimoto slim-line fan
STM external oil cooler
1g water pipe
1g thermostat housing
Ignition/Wiring:
Evo III coilpack and bracket
Magnacore 10 mm wires
NGK ES 0.030"
OHM Racing Mil-spec engine harness
OHM Racing Mil-spec fusebox harness
Fusebox relocated to glovebox
Battery relocated to trunk
Other:
VIS Racing Carbon Fiber G Speed Hood
FF oil dipstick handle
Boosted Fabrications Bumper supports
Deleted:EGR/emissions/ABS
Mods-Engine
Fluidampr crankshaft pulley
GSC Lifters
Eagle Rods
Manley Pistons
Kelford 272's
Kiggly High pressure valve springs
Mods-EMS & Logging
ECU:
AEM EMS Version 2
AEM Gauges:
UEGO AF/R
Boost
Fuel Psi
Oil Psi
Water Temp
AEM Sensors:
5 bar MAP
AIT sensor
EBCS
Other:
HKS turbo timer
GM Flex Fuel Sensor
Mods-Drivetrain
TRE Stage 3 Transmission
4 Spider Center Diff
BP transmission billet bearing housing
BP billet T-case housing
Southbend stage 4 extreme clutch
B&M short throw shifter
SS clutch line
White Shed Speed cable brackets bushings
Torque Solutions:
engine mounts
shifter cable bushings
shifter base bushings
drive shaft carrier bearing support bushings
Evo 8 Brembo's (front & rear)
Galant knuckles
ABS delete
3g brake booster / 3g master cylinder,
Feal 441 coilovers
RM sway bar (front & rear)
Volk front LCA's
CompWorks Fender braces
RRE front lower tie bar
DC Sports Front Upper & Rear Upper strut bar
Boosted Fabrications Chromoly Crossmember /Roll Stop
Bobby's:
rear lower trailing
rear lateral arms
bump-steer kit/outer tie rod ends
tubular front upper arms
tubular rear upper arms
4 point under brace
Background
Optimization
Eclipse 1998
Comments
2
More in 2G DSM
Share this Vehicle
