gsx tuningart
- 80
- 3
- Jan 18, 2005
Viterbo,
Europe
Hi guys,
my 95 gsx have around 350 hp at 15/16 psi boost. But max output from turbo is 20psi and i have the same hp.
i don't know if i need of something more .
Any advice is appreciated
This is the list of my built:
6 bolt block
Stock crank
Eagle Rod
Arias pistons 86,00 8.8
Arp head and main stud
King xp Rod and main bearing
Fidanza aluminium flywheel
Act 2600 pp act 6 puck disk.
Competition clutch fork
Cometic head gasket
7 bolt ported head
Magnus intake Manifold
1g throttle body
1g cas
Cams hks 272 272
3g lifters
Gsc valve stem seals
Fidanza adjustable CAM gear
720 injector
Aem fuel rail
Aem fpr
Walbro255 rewired
Dnp exhaust manifold
Mvr44 Tial
Greddy fv recirculate
2,5 piping and fmic
Aem Wide band
Omnipower 3bar map sensor
Ecmlink v3
Turbo : Garrett TB 03
C.wheels ex.68,9mm in.48,8mm
T.wheels ex.48,7mm in.58,9mm
Bullseyes housing
3" downpipe and cat back
Mbc
6 bolt block
Stock crank
Eagle Rod
Cometic head gasket
7 bolt ported head
1g throttle body
1g cas
Cams hks 272 272
3g lifters
720 injector
Aem fuel rail
Aem fpr
Walbro255 rewired
Mvr44 Tial
2,5 piping and fmic
Aem Wide band
Ecmlink v3
Bullseyes housing
Mbc
