What did you do to your DSM today?
finished up after putting new rtv on the oil pan after realizing it was leaking,so i replaced the oil pan gasket and no more leaks,got everything back together,filled with oil and coolant,bled clutch,let it warm up and drove it around,got on it turned tru boost down to 5 for the spring and it hauled like no other,checked when i got back and no more oil leaks,but well see
wished i had the money for a new turbo already! then started doing more research after looking at the aem engine management that i just spent my turbo money on! :)
Yesterday: Discovered the block I just bought is from Japan, out of a 1991 Mistubishi Galant VR-4 AWD Turbo.
Today: Started de-burring said block, interior and exterior.
Replaced the turbo to manifold seal on the 93" GSX. What a pita. 1 bolt broke off in the turbo, 2others striped the threads out. And the threads where stripped out on one of the j-pipe bolts. Fixed it all and got it back to running. It's not as loud now and when I can get rid of the coffee can out back life will be damn near perfect again.
Started my winter build,
FIC 950cc
Evo9 MAF
Stage 3 Keydiver Chip
Did a WOT pull on 17psi, and almost creamed my panties haha!!!
I changed the oil in the Talon. First time working on a car since early spring.
I sat down, and stared at mine for about 2 hours, and told it, it better run 9s next saturday!!! LoL
started by replacing the alternator, then moved on to stripping out the interior and removing all the excess wire from multiple systems that were hooked up from more then 1 owner, i removed at least 10 pounds of wire and home make sub box,and an old alarm that had wires going everywhere but they all ended up going no where, then gave it a good wash and cleaned the window so they were extra clean.
Lucky!!! Did it come with the 16g and yellow top injectors, mine came out of an rvr. ..
And today I flushed my radiator and added some good stuff like water wetter...oh yea!
took my oil pump off today because it went out on saturday...lucky me it went out two houses away =]
Went to shcool without my other dsm buddies knowing about my chip. Asked them if they wanted to race after school. We did. I smashed!
Guess who has the fastest car at Thornton High School again, THIS GUY!!
I re-routed my MBC from the engine bay and into the cigarette lighter hole. ;D So now I have a twist knob where the Cigarette lighter should be with a color-matched washer that keeps it nice and snug so it doesn't move around a bit. I'm lovin' it.
  • For sale 2g Early 95 2GA DSM Hardtop for sale (5-speed)
    2G DSM for sale
    • codexes21
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
