forcefed86
- 1,007
- 14
- May 23, 2006
wichita,
Kansas
Well I was bashed and instantly had 100 people telling me I couldn't do it. Well I did, and it works just fine. Nothing crazy rich on the shifts and no poor idle or driveabilty issues.
Installed LC2 WB02. Went for a test run...
First run with the BOV setup OEM style. At 18lbs WOT I'm seeing around 9.5:1 AFR's. Lifting to shift (BOV active) AFR's jump to mid to high 12's. Then jump back up to 9.5:1.
Swapped in my brass check valve vented to atmosphere. PLugged open hole on intake tube. Same WOT AFR's same boost. At the shift AFR jumps up a bit less at 10.2-10.6, then drops back to mid 9's.
So there it is... do what U will with it. It's sure not washing down any cylinders running at 10:1. That is leaner than the factory map!
The factory AFR targets are as follows.
Also for what it's worth I've done the "dodge garage" MOD to the BOV. If anything this probably slows down the BOV, but thought I'd mention it.
Simple brass check valve installed. I've since painted everything black. But this pic shows the valve assy better.
. In the long run you'll be happier with a recirculated dodge garage modded valve if you're going to stay with the maf.
