forcefed86
- 1,007
- 14
- May 23, 2006
wichita,
Kansas
Well I was bashed and instantly had 100 people telling me I couldn't do it. Well I did, and it works just fine. Nothing crazy rich on the shifts and no poor idle or driveabilty issues.
Installed LC2 WB02. Went for a test run...
First run with the BOV setup OEM style. At 18lbs WOT I'm seeing around 9.5:1 AFR's. Lifting to shift (BOV active) AFR's jump to mid to high 12's. Then jump back up to 9.5:1.
Swapped in my brass check valve vented to atmosphere. PLugged open hole on intake tube. Same WOT AFR's same boost. At the shift AFR jumps up a bit less at 10.2-10.6, then drops back to mid 9's.
So there it is... do what U will with it. It's sure not washing down any cylinders running at 10:1. That is leaner than the factory map!
The factory AFR targets are as follows.
Also for what it's worth I've done the "dodge garage" MOD to the BOV. If anything this probably slows down the BOV, but thought I'd mention it.
Simple brass check valve installed. I've since painted everything black. But this pic shows the valve assy better.
Now, let it die. You're own motor ran much richer. Mine and justin's stall, and Spyderturbo's car runs like a$$ with it not recirculated.
with this post.
don't expect a tip.
Without it you won't be able to vent properly.
. Still didn't run well. Because the bypass valve opens during idle and light cruise. With a check valve you would remedy the idle and part cruise. But I still also had WOT shifting problems. In between shifts during a run the car would stumble terrible. At those times air is soley escapping as any check valve would allow, except for one with such high crack pressure that it would render the bypass valve useless.
