forcefed86
- 1,007
- 14
- May 23, 2006
wichita,
Kansas
Well I was bashed and instantly had 100 people telling me I couldn't do it. Well I did, and it works just fine. Nothing crazy rich on the shifts and no poor idle or driveabilty issues.
Installed LC2 WB02. Went for a test run...
First run with the BOV setup OEM style. At 18lbs WOT I'm seeing around 9.5:1 AFR's. Lifting to shift (BOV active) AFR's jump to mid to high 12's. Then jump back up to 9.5:1.
Swapped in my brass check valve vented to atmosphere. PLugged open hole on intake tube. Same WOT AFR's same boost. At the shift AFR jumps up a bit less at 10.2-10.6, then drops back to mid 9's.
So there it is... do what U will with it. It's sure not washing down any cylinders running at 10:1. That is leaner than the factory map!
The factory AFR targets are as follows.
Also for what it's worth I've done the "dodge garage" MOD to the BOV. If anything this probably slows down the BOV, but thought I'd mention it.
Simple brass check valve installed. I've since painted everything black. But this pic shows the valve assy better.
its all good I just didn't know what you ment, and thats what came up when I searched.
Feel free to do whatever you want to your car. If you do vent, and you wind up having problems, don't point to this to this thread and say "see, it's ok to vent, whats wrong with my car?!". When I was on the vented mass air setup I would get huge piles of black smoke each shift and foul out the plugs every 1000 miles or so.
I switched from evo mas to 2g mas to my maft. All of which i was using my hx40. Maybe i was over-running the evo and 2g but i noticed nothing but good things such as boost recovery and spoolup from a running start. So i can't agree with you on this.
