forcefed86
- 1,007
- 14
- May 23, 2006
wichita,
Kansas
Well I was bashed and instantly had 100 people telling me I couldn't do it. Well I did, and it works just fine. Nothing crazy rich on the shifts and no poor idle or driveabilty issues.
Installed LC2 WB02. Went for a test run...
First run with the BOV setup OEM style. At 18lbs WOT I'm seeing around 9.5:1 AFR's. Lifting to shift (BOV active) AFR's jump to mid to high 12's. Then jump back up to 9.5:1.
Swapped in my brass check valve vented to atmosphere. PLugged open hole on intake tube. Same WOT AFR's same boost. At the shift AFR jumps up a bit less at 10.2-10.6, then drops back to mid 9's.
So there it is... do what U will with it. It's sure not washing down any cylinders running at 10:1. That is leaner than the factory map!
The factory AFR targets are as follows.
Also for what it's worth I've done the "dodge garage" MOD to the BOV. If anything this probably slows down the BOV, but thought I'd mention it.
Simple brass check valve installed. I've since painted everything black. But this pic shows the valve assy better.
. It worked with your car because you lifted completely off the throttle activateing the fuel cutting idle switch. No one drives like that. And even if it does work for you, there's too many proven bad experiences to take just your word for it. You can't beat statistics. You can't beat statistics. You can't beat statistics. You CAN beat your head on the wall in attempt to disprove them. But you can't beat statistics.
you need to stop. Your car didn't run so rich that it stalled. So what?
Everytime I read that post I just gotta laugh.
just dont try and push it on to other people that its okay to do an wont have an side affects. You cant tell me any different because i ran open bov since day one with my car and the idle blows its not smooth at all between shifts and it makes your car run rich, rich enough that you can smell it in the exhaust, and it also carbons up the exhaust and 02 housings after enough use. I switched to gm mas and love it. I like running open blow off valve and i will continue to do so because i think its awesome and its so much better doing it the right way. MY 2
