Diastar
- 0
- Nov 28, 2015
Calgary,
AB, Canada
Currently running 10~ PSI out of waste gate. I would like to run around 15 psi, however I'm not sure if it's safe to use a manual boost controller to get there. I know the factory tune is designed to run off a turbo but is the ecu adaptive to different boost? will I do damage running at a boost increase without a new ecu or tune?
