Want to go faster ,next step?
kurt fuhlbrigge
92
Feb 18, 2008
canaan, New York
I am looking for a little more out of my GSX . Profile should be up to date minus the fp race manifold I just installed .Nitrous is off , we'll save that for later . Spraying # 7 meth nozzle around 10psi .I have a big 16 G that came with the car .Seams to build around 21psi at about 5000 rpms but then falls of to about 16 when reaching 6000 rpms . Did a boost leak check, seamed ok .Not sure about the miles on turbo ,could be an ebay junker . Will a tired turbo fall off like that? I would like to make around 425 hp without beating the death out of the turbo . What will the e3 16g do?I would rather not spend a fortune . Is porting worth it and what does clipped do? Would the 900$ fp turbo do what im looking for ? Thanks
If the turbo is blown you will be blowing smoke out of the exhaust. You could port the turbo and o2 housing for a couple of horsepower. a evo3 is good for an efficient 21 psi w/o meth injection but since you have it you could run more and advance your timing. But for your power goals just go with a bigger turbo fp green or red or an hx 35 or 40. Just the easiest way to gang what you are looking for.
I have had people tell me Im smoking alittle when I get on it . I thought I was still a little rich in my tune . Motor is new ,800 miles ,turbo ?.Is not being able to maintain pressure a sign of a bad turbo? Is this something you would pick up on a boost leak test?
Making 425 horsepower out of that 16g is not going to happen. What do you have for fuel mods? Do you have a front mount intercooler? do you have a wideband?
Is there another way to determine whether the turbo is no good?
yes I know 425 is not gonna happen on the 16G .If I have to buy a new turbo thats what Im looking for . Walbro 255, 650 injectors ,yes fmic ,yes wideband , tuning to 12 afr with the meth injection .Also DSMlink
