Uncrimped connector pins, where to get?
ramsack
3,288
23
Dec 27, 2007
West Lawn, Pennsylvania
does anyone know where to buy the various types of pins or connectors on our cars? as i mod stuff now and then i prefer to do wiring as short as possible and direct as possible (i.e. no soldering even.) so i was wondering where to get uncrimped pins. also it would be cool to make a complete new engine harness with nicer and fewer wires :D
no prob.... BTW they should be listed in the NAPA Balkamp catalog or the wiring assories
i finally went to napa to check out that balkamp catalog and it's all domestic connectors and pins. i called a bunch of different places that make harness type stuff for our dsms and they don't want to seem to help me or can't. does anyone know where else? i've also looked at mouser's catalog and they have some stuff that is close. on the coil plug there are plastic inserts and it says ocs or sjo on them if anyone knows what that means?
I don't have the information with me at work, but bump this thread tonight and I can get you the part numbers for the ECU pins. Thats all the info I currently have.
yeah i looked through amp/tyco and molex before posting the last post. i have mouser and digikey catalogs at home too. no luck yet. i guess there are only a few connectors like the isc, tps, and cas that use plugs that can't be found. i may have found the ecu connectors on tyco's site.
i guess there are only a few connectors like the isc, tps, and cas that use plugs that can't be found...
There is one poke you can go search on and that is at Carquest. I had to replace a sensor where the original connector wouldn't fit on the replacment sensor, but they do have, what's called 'pigtail connectors' - where you snip off the original connector and replace it with the newer 'pigtail connector' by splicing it back on the existing wires so it will fit on the new sensor.
Good luck-DSM
cool. i'm also thinking with the cas, tps, and iac i can maybe get them from the '90 and use my own connectors.
Most of the plugs on our cars were manufactured by Mitsubishi Cable America; if you see a logo of "SJD" (where the "S" is a little lightning bolt) molded into the plug, that's who made it. Unfortunately, that doesn't help you much; MCA won't deal directly with the public, unless you have a significant quantity order to place. (In the past, they've been receptive to trying to find a one-off part for people in need as a sample.)
Almost all of the plugs they produce, however, are some derivation of a plug made by Tyco/AMP, JAE, or Sumitomo (or you can sometimes find a Bosch plug to mate with them, if you squint at it a little bit). Most of these companies offer engineering samples, if you need one or two of something for a personal project; just poke around their website a bit to find it.
I've been collecting ECU-related connector information for Evos over here, which might give you a starting place for some of them; my best advice is to get very comfortable with the product catalogs from Tyco, JAE, and Sumitomo, because you'll be visually cross-referencing is most cases (although Tyco's online search is actually pretty good; Sumitomo's sucks, a lot). In a perfect world, I'd love to see this tech article updated with actual manufacturers and part numbers for each plug (and a similar article written for 1gs, of course). :)
Good sources to search when actually trying to purchase these connectors include:
Ballenger Motorsports
Eastern Beaver
DigiKey
Mouser
Newark
Online Components
SpoolinUp
New United Race Tech
Hope this helps.
Eastern Beaver
DigiKey
Mouser
Newark
Online Components
SpoolinUp
Hope this helps.
Just out of curiosity, when did you publish or find all the information regarding 2G DSM/Evo ecu connectors and pins?
According to the wiki history, it looks like I created that page late last year (and it appears that I'm the only editor who cares about pins and connectors ;)), although that information has been floating around EvoM in one forum or another for quite a while (and that was the problem; finding any of it was a huge PITA).
There's quite a few people to thank for what's there now; 0xDEAD/danl, in particular, tracked down most of the IX stuff (and probably at least a few of the 2g/VIII info), I think I was the one who did the legwork for the 1g plugs and pins, and I believe Jack_of_Trades and mrfred were probably to thank for originally pointing us in the right direction for the VIII/IX pins. I'd only be guessing if I tried to remember who found the EGR or BCS plugs. I take very little credit for any of it, other than filling in a few gaps and tracking down commercial sources for some of them.
I'll also note that it's a wiki, so I'd encourage folks to create an account and update it if they have information to add; the information there is pretty Evo-centric, but the Development section is pretty free-form (and is slowly accumulating some 1g information for the Evo ECU swappers).
awesome stuff. i guess i see how some of the newer connectors will fit even though they don't exactly look like oem ones.
Alright, I guess that's good to know. Back when the Evo ecu was first being put into the 2G cars I didn't want to pay for a patch harness so I set out to make my own. I spent so much time it was silly trying to find the exact pins and connectors. Luckily for my sanity, I did all my work before that stuff was posted.
I'll be sure to look over it again and see if I have any information saved on my many spreadsheets regarding the pins and connectors.
Hey Dan. :) Yeah, I ordered a bunch of pins from them as well, and linked to them in my post above; pretty painless to deal with. I think onlinecomponents.com had a bunch of those older pins as well, didn't they?
(I just need to get this damn turbo install finished, and then I can go back to working on putting the IX ECU in the 1g. Someday...)
