2G Where to buy connector pins?
starscreem
128
May 2, 2005
hoffman estates, Illinois
hello
ok so my problem is i bought a project car knowing the pump did not work, well that was kinda easy to figure out once i opened the tank up to put in a walbro 255hp i got from a friend. well the tank was full and had probably almost 2 years old gas in it. well it rusted the hole sending unit and siphon pump unit and smelt like turpentine or some thing bad, well i disassemble them and cleaned them up and put in the new pump and still could not get the pump to fire. well i took a closer look at the assembly and after checking for power at the pump connector. i had power on top of the cradle fine so i looked on the tank side and realized that all the pins on the plugs a really corroded and need to be replaced. i did wiggle the fuel pump ones and it fired up for a sec and one just broke off. so my question here is were can i get these pins so i can fix this i went to radio shack, autozone , and advanced auto, and had no luck.
here are a few pics of the pins i need
