2G New Interior Connector Pins (Male & Female)
MattHDSM
5+ Year Contributor
113
73
Oct 20, 2018
Ottawa, ON, Canada
I found a source for OEM style male and female pins for the interior connectors. With pretty much all the old suppliers for pins gone, it was very difficult to track this style down. The only readily available Canadian source was Mouser, but searching the part number may yield other sellers as well. The TE 175269-1 female pins that are often recommended on this site are probably only meant for exterior/engine connectors as they have locking "feet". Those will work for interior connectors as well if you flatten the "feet" flush with the body. I could not find any info on the male counter-part to those TE female pins.
Yazaki 7114-1471 Male
Yazaki 7116-1471 Female
Mouser.ca 71141471 Male
Mouser.ca 71161471 Female
Yazaki 7114-1471 Male pin compared to an OEM male pin
Yazaki 7116-1471 Female pin compared to an OEM female pin
Differences between Yazaki (top) and TE (bottom) female pins
Good find man. I was doing a lot of this research as well back when I was trying to pin my own SD and FlexFuel sensor stuff into the mafs without buying the ecmtuning harnesses. Found pins from some places but the problem was you had to order them in like a 200 count and I was not wanting to do that LOL.
I was going to buy bulk pins from Aliexpress and hope for the best because I couldn't find anything, but a fluke of similar images, some dimensions, and luck led to me finding the above part numbers and subsequent part diagrams/dimensions. Fortunately there seems to be no minimum order size from mouser. I bought 25 of each, but could have bought just 1 I'm pretty sure.
