Two Questions.
isaiddurazoo
77
Dec 14, 2011
Tucson, Arizona
1. Will an srt4 fmic mount right up to my eclipse? To my understanding fmic's are universal. I was looking at the slimmer design of the srt4 fmic aand maybe I could get away with not having to cut out the dumper support. I know it won't be as efficient as a bigger fmic but it would do a better job than a sidemount and I can pick one up for cheap. So will it fit?
2. My 4th injector (farthest from the camshafts) continues to go out, I've replaced it twice already and I have no idea what the problem could be. When the car sits for about 24 hours it begins to work again. SO I don't believe it clogged and maybe its more of an electrical problem? Maybe the ecu? Whatever tells the injector to squirt?
1.) no, the SRT4 FMIC has the IC piping holes facing the motor, so you'll have to modify the end tanks to run to the sides so that you could run piping to it.
2.) i would double check your connector, maybe clean it out with some compressed air.
The SRT intercooler is a good piece but like talon2gbuyer stated not bolt on.
Do a continuity test from the ecu plug to the injector plug to assure there are no breaks in the wire. Hopefully its not an injector driver in the ecu.
