Two questions...
Rklock
Aug 19, 2009
Cb, Iowa
What is considered good oil pressure at idle? I have about 25lbs at idle...is that good?
How do you know if your slave cylindar is going out on a fwd laser? My tranny tends to want to pop out of gear when i go to downshift into first even at a dead stop...
Well, 25psi at idle sounds just fine. If it's popping out of gear, that sounds more like a synchro or a bearing in the trans failing. A bad slave can't do that. If the slave was crapping out, it just wouldn't go into gear, or your pedal might get stuck on the floor, etc...
