Two quick questions...
deadlyforce
131
3
Feb 20, 2006
Hagerstown, Maryland
My first question is simple, what should the oil pressure on a 99% stock 1995 GST sit at on the stock gauge. Mines idles/rests at below the first line, but then will raise to half, sometimes three quarters when running hard (accelerating on the highway)
My other question is about a flex pipe for said car. My exhaust is screwy due to a hole in my flex pipe, and the only affordable place I have found to get one is Slowboy. Does anybody know the size I need for my 95 GST?
The stock guage is inaccurate, and it is common for oil pressure to fluxuate.
The stock size is 2.25", get a 2.5" and you will be fine.
Dustin
Your readings on your stock gauge seem fine, if you are driving around and it is reading below the lower line I would take a look and see whats up.
Your best bet for the flex pipe would be to head to a local muffler shop and have them weld in a new piece.
