90laserRSfwd
- 1,411
- 87
- Mar 5, 2007
Elizabethtown,
Pennsylvania
Ok so I just spent 6 hours of my life over the last 4 days reading post after post and I didn't find a thing that has to do with tuning e85 with dsmlink. I info I was looking for wasn't to be found (not by me anyway) so hope this helps.
some quick info...
when I say gas I'm refering to premium unleaded fuel (93 oct in my case)
when I say e85 I'm refering to 85% ethanol (summer blend)
I have a 1992 Eagle Talon (fwd turbo). It's currently running 950cc FIC injectors and a 255 high pressure pump with an aermotive 1:1 fpr. Check my profile for mods.
ok here goes....
stoich for gas is approximately 14.7:1
stoich for e85 is approximately 9.765:1
http://en.wikipedia.org/wiki/E85_in_standard_engines#Air_fuel_ratio_comparison
^^^ here's the link for the stoich of the e85 I'm talking about^^^
I have a gt35r turbo and want to tune my car (I have dsmlink) to run around 27 to 30 psi. My hp goal is around 500whp. Don't post a response if you don't know the answer, I'm going to be very upset if I ruin a new motor over some wrong advice.
ok on to my questions
1. Do I need to up my injectors? (If so what size)
2. How do I tune the dsmlink to make up for the fuel requirement difference's, I've been seeing you need to add approximately 27 to 33 % more fuel.
3. Can I set up the Innovative xd-16 (the wideband I just ordered) to show my 9.7:1 is stoich instead of 14.7:1, and if so how do I do that, if not how do I tune using the 14.7:1 as the stoich setting. I just got my dsmlink the other day and didn't get to register it yet so I don't have access to the dsmlink forums. This question may be answered there already. If so could someone post that info here (as apposed to just linking to it, so all of us can see it and use the information).
4. I'm currently running NGK 7 (brp7es) plugs, do I need to go colder then that?
5. I have an ACT2100 with streetdisc now (my current clutch) and I was thinking of going to either the 26 or 2900 when this one goes out... should I get the street disc again, or the sprung race 6 puck.. Perhaps a different clutch like the SBR 4500???
5. Anything you can add to this would be greatly appriciated
Thanks in advance
Jayson
some quick info...
ok here goes....
Thanks in advance
Jayson
