chrysler kid
- 3,552
- 1,150
- Dec 20, 2002
Mckinney,
Texas
To add in .02 cents
The thermal efficiency of a stainless steel 3 inch downpipe is reduced compared to the original smaller downpipe. The aftermarket pieces also lack heat shielding and insulation
Theory of thermal effeciency is that the hottest pieces of the exhaust will eject the cooler exhaust gases faster out of the tail pipe. If your cast iron exhaust manifold and exhaust housing are exposed they are not consistently hot enough to expel the hot combustion gasses quick enough. It doesnt matter how far open you port the 02 housing, if its 120 degrees hotter than your downpipe, the exhaust gasses are going to stay up by the 02 housing and not expelled further down the exhaust.
You can argue the larger downpipes cause creep, however it's because of their expanded diameter that the downpipes stay colder and causes the hottest exhaust gases to concentrate back up to the 02 housing and turbine hot side.
Heat wrap everything and retain your factory heat shielding or use a turbo blanket. They are used to prevent heat from exiting the iron and being the hottest pieces helps them expel the hottest exhaust gasses faster
I also dont like aluminum radiators, I feel they contribute to higher underhood engine temperatures while only offering a negligible coolant effeciency increase that is often just lost because most aftermarket slim fans flow at lesser rates than the original fans. But thats a more controversial opinion and really only applicable to street cars and not race applications that see regular high speed ventilation
