Trouble Removing Drive Axles on my Eclipse
Jonny353
Oct 11, 2007
Killeen, Texas
I have run into a bit of a problem. I have a 99 Eclipse N/T and the CV boots are ate up so I decided to just change the entire drive axle assembly. Well I got everything off and even pulled the drive axle apart at the inner CV boot but I can't get the part of that axle that goes into the transmission to come out so I can put the new axle in. Any tips on how to get it out? Or will I have to go into the tranny and do it that way? thank you all for the help.
Use a flat head screw driver and a hammer and lightly tap between where the axle meets the transmission and it should pop it free.
Do this and have another person pull from the other end, and when pulling keep the axle as level as posibble. This is the easiest way I found to remove axles.
You don't wanna pull too hard on that axle or your likely to pull the axle knuckle out of the hub.
just removed both today on a 2g,one pulled out easily by hand,the other used a pry bar to pop it out.........
Picked up a pry bar to lock my wheel when removing the hub nut so will try to pry it off with that, if that fails will give the slide hammer or screw driver and hammer trick a try. Thanks for the help.
You should drain the fluid, but you don't have to, just be prepared to catch some that comes out when you pull the axle.
Use the screwdriver and hammer and lightly tap and while rotating the axle, it's the easiest way. You'll get it out in seconds. You just have to wedge the screwdriver gently and tap a hammer as you rotate it.
Be careful not to tear the axle seal. They'll cost you 26.00 for the drivers side and 6.00 for the pass side.
  • For sale 2g NOS Sebring/Avenger floor mats
    These are slightly different shape than 2G mats but very close. NOS and still in plastic wrap. I...
    • MindBlowin03
  • Wanted 2g Anyone parting out a 2G?
    Need a few bolts that I'm missing for the rebuild, subframe and crossmember specific. Anyone...
    • Mahreeoh17
  • For sale 4G63 Mitsubishi # 284K00708 tach filter
    Mitsubishi OEM tach filter. With weather pack connector. Message 702-741-6987.
  • For sale 1g NEW ETS Street Intercooler for 1G DSM ( 4” Core )
    NEW ETS Street Intercooler for 1G DSM ( 4” Core ) $475 + shipping & paypal fees* these are...
  • For sale 2g 2g power window motors. OEM
    2g RH and LH power window motors OEM, $30 each. Sold the drivers and pass set of door switches...
