2G Thermostat housing neck bolt size?
Its an M8, length unsure for oem but i swapped mine out for some 25 or 30mm length ones i believe. How did you break a steel M8 bolt in an alloy housing? I can only assume it was a corroded weak bolt to begin with as that shouls have stripped out the housings threads
