The GSX runs a mid 11 on pump gas
Boosted98gsx
2,099
22
Oct 31, 2002
Houston, Texas
Went to Texas Motorplex in Ennis Texas on Friday. After getting used to launching the car (and some crap >2.0" 60 foots from 2nd gear mis-shifts), car finally dropped into the high 11's at ~120mph. Continued running the car on pump gas and refining the tune to vanish the 1* of knock I was getting in 4th gear, and working on my NLTS technique (which is REALLY nice not having to re spool up a GT35R after shifting).
Finally achieved a 11.64 @ 114 as my alternator belt shredded off in 3rd gear. I basically coasted through the 1/4 mi line and after getting through the slip handout post (thinking it was a 12 second run from the engine trouble). Immediately, I stopped the car as my battery light, check engine, and brake light came on, as well as the coolant temp gauge reaching up high. Let it cool down as I inspected under the hood to find some "strands" of a belt laying about. Go figure.
This is the 2nd alt belt my car has eaten, and the autozone belt is already at full tension on my car. I cannot for the life of me get these things to stop squealing.
Good run, I had the same problem when I installed a new alternator. My motor finally gave out. So hopefully with the new motor install it won't happen again.
Decent times, congrats. Quick 2g.
Get a goodyear Gatorback belt. they're top notch, no squeaks, no slips.
Nice times. You should be faster w/out all your problems! get her fixed and get back for some more runs! Nice!
Have you checked the inner ridges of all your pulley's for chipped-
grooves or corrosion build-up,you should not be eating belts like that
I personally use factory belts I get the squeaks too but I just titan it
a little and it goes away.
Nice car bro. Hope your next alternator belt works better and you hit a better time.
And KingAWD, you erase the license plate number in the car rear, yet leave it exposed in the front...how come? I don't get it!
I had the same alternator problem. Check the pulley for debris and other shit laying in there and clean it out.
Went back to the 1/4 last friday (8-8-08) on 5 gals of VP c16 and ~5 gals of 93 octane. Got the boost to 28 psi, but first gear is now useless, and a 1.8 60 foot was all I could muster, bringing the car to an 11.59 at 125mph. Still on the OEM non-lsd rear end, and an open 4 spider center diff. Time for an investment in some M/T QTP slicks and cheap drag wheels.
We'll see how she does when this next drivetrain upgrade is finished.
    • george bromwell
    • pma1123
    • Sdcryan1
