The 14b Drag Race Discussion Thread
I finished up a few things, poured in some new brad penn 10-30. Then I fired the beast up tonight. She sounds great and should be good to go for march 3rd at a lower elevation track. Got a few more suspension bugs to work out though. I'm getting excited just to hit the track again.
Nice man, good for you. Best of luck on hitting 10's!
Good luck! Can't wait to hear some results.
Thanks a lot guys. Every day that gets closer the more anxious I get. Ill be going over the car pretty good over the next couple of weeks just to make sure I have a good day at the track. So much to do and so little time.
Looking forward to seeing this car at the track on 3/3!
As long as you get a solid run in, I doubt it will disappoint. Even if you don't get the record, a clean pass should result in a new PB with the 14b.
That's usually all I go for when I go to the track. If I can better a 60' time, 1/8 time, or overall ET then I'll be happy. I really need to get my SD tables lined up so I can get a better tune on the car and know where I'm at with it. So I'm gonna try to hit the track the day before the CMI race so I can get some things dialed in for Sunday. Then hit it hard.
That sounds like a good plan, Justin. Wish I wasn't going out of town for 3 months or I would be up there to get some video for you guys!
That's right get that 14b pride out there :hellyeah: we got to let these folks know what's going on! I'll for sure be looking forward to it!
On another note, i'm getting real tired of this "hair drier" effect. Tried out a couple simple brief 2step's today, now that i'm not on spring pressure. The first one built 14psi@4k rpm, let it idle for a little bit than tried again and got a jolt of +21psi@4k rpm while picking up some knock too.. Ouch :ohdamn: the water/meth pump was working for sure but something isn't right. It seems i can get the AFR's to go down when i press the test button at idle but it has no effect while boosting for some reason, even with a bigger nozzle. Will be troubleshooting this weekend with compressed air..
Got a chance to troubleshoot today using compressed air, everything checked out fine. I guess, it just needed an even bigger nozzle! Drove the car around while making 3 small pulls in the 20psi range, came back to the driveway and did another split second 2step, it took less than a second to build 17psi@4k with no knock this time. That's what i like to see.. whenever i look at the log and see those voltage spikes, it feels almost like scratching nails on a bath tub :notgood: Thinking about making another video of it, if i get motivated enough. LOL
:nono:
Where's the confidence!?
You'll be fine.
I predict [email protected]
He is just down playing it to take some peer pressure off himself :p
:nono:
You'll be fine.
Ohhhhhhhhhhhhhhh predictions, I like that.
You've Been around long enough. I'm sure you already know every trip to the track isn't very successful. I'm very anxious about this race because me and Sacramento raceway don't get along very well. I'm might have to finally step up and make that track my bi***.
I already catch enough grief from nut swingers of others that are making an attempt to make an attempt. And I really don't talk up how badass my car is. Maybe I should brag about my meth, and aluminum rods, and custom gears.
And this is what i get for driving my 14bcharged classic car on public road.. :banghead: Some mini van decided it was a good day to plow into the back of my car, while i was trying to pull out onto the freeway
This is also the main reason i have an identical twin car :rocks: Still sucks though..
One more week guys. I plan to hit it hard. Car weighed 1876 race ready no driver. So she's on a good diet unlike the driver. I'm gonna try to test the brakes out this week but I'm ready.
Hey Justin, what's the total race weight with you? A little over 2k lb? Just curious for when I get back home and get mine back together.
  • For sale 2g Early 95 2GA DSM Hardtop for sale (5-speed)
    2G DSM for sale
    • codexes21
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
