- Thread starter
- #26
miliman13
- 2,495
- 695
- Jan 1, 2011
tampa,
Florida
Before you go buying a new dash gauge (or at least in addition) you should also make sure the senders and wiring are working as they are normally connected in series to ground. Unplug the driver's side fuel sender 4 pin connector. Connect your ohmmeter to the harness side all yellow wire and the other ohmmeter probe to a metal ground (no need to turn key on). Make sure the reading is between 4-107 ohms depending on how full your tank is (4=full, 107 is completely empty). If you don't have this you also have a sender/wiring problem independent of any dash gauge issue.
A little confused now. I thought that's what I just did in the previous post.
In the image I'm testing resistance on solid yellow wire and grounding to chassis.
But I thought that measures the gauge...
, no problem.
. [To test the solid yellow with everything plugged in I stick a sharp pin through it's insulation.]
