1G Fuel Gauge and Temp Gauge Too High
allezgrand
85
Dec 11, 2003
Boulder, Colorado
  • Running ECM Link V3
  • The regulator on my old alternator was bad and the alternator was spiking up to 19.5 volts at times. I replaced it with a high output BNR alternator.
  • With the new alternator, voltage from the battery is ~14v, consistently when running.
  • Voltage from the B/W wire out of the ignition reads about 1v less than the voltage from the battery. Is this normal?
  • My fuel gauge is now maxed out always. My temp gauge maxes out when the coolant gets over ~120F.
Anybody have any ideas what may be causing these issues? What would you check next?
Sounds like a grounding issue at the gauges. Measure from the gauges negative pin to ground. You will have to pull the dash to test D04 pin 1.
Also check that the alternator is well grounded. The case of the alternator and battery negative should be under .1v when the alternator is charging or resting.
  • For sale 4G63 Planetary Gear Sets ( for 1G & 2G )
    Planetary Gear Sets $175 a piece + shipping & paypal fees* fit 1G Auto GSX/GST * fit 2G Auto...
  • For sale 4G63 Motegi Traklite Wheels & Tires
    Motegi Tracklite Wheels & Tires $650 17X8 5X114.3 Offset +45 2 Toyo Proxes 235/45R17 Tires 2...
  • Wanted 2g 2g Hood latch support
    On the hunt for the support that holds the hood latch assembly.
    • jesse12345
  • For sale 4G63 Hallman ES Boost Controller
    Boost controller
    • jpturbotalon
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
